Brake Tolarance/Minimum
Old Jun 7, 2017 | 11:36 PM
agent325's Avatar
agent325
Default Brake Tolarance/Minimum
I'm having a PPI done on a 2012 997.2 base carrera. The brake measures are the following.
Front Disc - 27.8 mm
Front Pad - 3 mm
Rear Disc - 26.3
Rear Pad - 5 mm
Do the brakes need to be replaced?
Old Jun 8, 2017 | 12:52 PM
shewu's Avatar
shewu
Front pads should be replaced. Rear pads are under 50% iirc. Rotors seem fine.
If you will track the car, rear pads may as well be replaced. Thin pads do more damage to rotors than thick pads!
Old Jun 8, 2017 | 02:35 PM
himself's Avatar
himself
First I've heard of this. How does that happen?
-td
Old Jun 8, 2017 | 05:09 PM
BIG smoke's Avatar
BIG smoke
-td
Thick pads help dissipate the heat.
Thin pads transfer the heat into the rotor, increasing the chance of warping the rotor.
What is the charge for 4 rotors and pads at PPi time?
Last time I shopped for these parts they were about 12oo-14oo ish. Depending on your shop, some turn the rear, and slide in new pads. Never had any success turning any front rotor on any car.
Old Jun 8, 2017 | 06:35 PM
frankyluis23's Avatar
frankyluis23
I think the front and rear brake rotors should be discarded at 26 mm. I am looking for the documentation to back that up.
