PSE & Laguna Seca - Any experience/recommendations to avoid 90 dB limit?
Hi folks,
Taking my .2S to Laguna Seca tomorrow.
It's 100% stock, but that includes the PSE option.
I've heard that might trip the 90 dB check at turn #5. The obvious mitigation is to short shift and take it a bit easy in that section
Was wondering if any here have experience and recommendations to get the best out of the car, but avoid the dreaded black-flag for sound?
Thanks.
Karl.
Thanks.
Karl.
I run at Lime Rock a lot, which he an 86db limit. A lot of ppl including myself have claped elbows onto the exhaust. The idea is to move direct the exhaust away from the sound meters.
I've been to L/S a number of times and have never been black flagged for noise (997.2 GTS). Just turn off the PSE and you should be fine. (Plus, I have a center bypass which probably ups the PSE off sound slightly.)
Karl.
Thanks everyone.
I did as lurchphil and Tcc1999 suggested and simply ran with PSE off. Up to and including the 2nd session, had no problems hammering past the sound booth and up the hill.
But then I had to abandon the day because I boiled-the-effing-bejesus out of the brakes so badly that they couldn't even stop the car from 10 mph while tootling around the paddock.
I wasn't even going that hard (~1m55s laps). Everyone there was super encouraging (TMR track day), saying get them bled, etc. But I kinda lost confidence in them and decided to bag the day (vague recollection about discretion and valor).
I got the car ~3 months ago and said "I'll leave it 100% stock because you've poured way too much money in mods on previous cars".
Well... lesson learned.
I'm going to get on the phone with ECS tomorrow and ask them for guidance on a full set of ducting (front and rear) and proper fluid, and see how that goes.
Karl.
Karl.
With ducting, fresh SRF600 and braking less you should be okay with an S
Consider Pagid RS29s but on a street car they shriek and throw off a ton of dust
If you don't need to worry about clearance cup ducts are much more effective
I've run LS many times in my C2S without any issues. I don't even think about it but I don't have PSE. A buddy has a Gundo Hack which is similar to PSE and he's been black flagged. Just leave it off and have fun.
Well... lesson learned....
Basic Sponsor
Thanks everyone.
Karl.
Karl.
Porsche Performance Specialist
John@Fabspeed.com
215-618-9796
Fabspeed Motorsport USA
155 Commerce Drive Fort Washington, PA 19034
www.Fabspeed.com
John@Fabspeed.com
215-618-9796
www.Fabspeed.com
Thanks everyone.
Karl.
Karl.
Just saw the posting ... my reply is too late, but sounds like all was good except brakes.
Another point of reference - I have 997.2 w PSE and leave it on and never had an issue at LS in the 90db days.
A brake fluid bleed and/or upgrade (some type of racing brake fluid) may be in order if you return to LS. It is a hard track on the brakes so it is important to have proper maintenance prior to any track outing. I've been happy with RBF 600/660 or SRF - the main advantage is the time between your brake bleeding can be longer with the specialty fluids. As for pads, I've experimented with several brands / styles and found that by the end of 2 full hard days, almost any pad is worn down to the point of replacement.
