997.2 C4S Front Differential Seal Replacement
Here is a DIY for the front diff seal replacement. I noticed a darker , moist, area on my front left under body cover last time I stored my car on the lift. Removing the panel it was apparent that the left front diff seal was starting to go when compared to the passenger side. (perhaps a high speed run may have sent it over the edge, and no point in waiting till there are drops sitting on the hood of my wife's Cayenne. I elected to not drop the differential as I decided to just repair the leaking side.
In hindsight, I think it would have been easier to undo the lower ball joint nut to free up tge wheel assemby rather than the main and diagonal control arms
remove front underbody cover
remove diagonal bracing arms 74 ft lbs
remove front tank covering straps 17 ft lbs
remove 6 allen head screws on axel shaft to differential coupler 29 ft lbs
loosen front Differential support Nuts 48 ft lb then remove the hex stud out of Differential and support.... diff won't fall , this gives you another half inch to help remove half shaft.
Now to free up wheel assembly and pull out the axel shaft coupler to give you room to take the half shaft out of the differential
Lower control arm from body
Front control arm from body
Tie rod
Main control arm position sensor
Rear vertical torsion bar connector, lower . Jack torsion bar up to give room so suspension sensor holder on control arm clears torsion bar
Pull pry wheel assembly w shaft out to give room to pull half shaft out
A quick pry will release half shaft from diff
Wiggle half shaft out
Reinstall front diff bolts to hold diff secure
Pry old seal out long pry bar and wood for leverage
Install new seal
Put everything back together
Diagonal cross support loosened, can be removed or swung forward by removing rear nut. Black tank cover strap above Diagonal support.
Allen socket in 1 of 6 allen screws holding axel shaft coupler to half shaft coupler. <br/>
Screws ready to be removed. I marked one screw ( black lines on axel coupler and then scribed a line on the black metal half shaft coupler) so I could reinstall at same alignment. Brown differential seal is evident on the right
Main Differential support stud with Hex socket on it to be removed
Main control arm pulled out from frame. control arm position sensor removed from bracket. Torsion bar vertical linkage removed from Torsion bar. ( torsion bar jacked up to give clearance for control arm sensor bracket (black piece on arm))
closer view
Front stabilizing arm pulled out
Tie rod removed
Half shaft removed from diff
new seal
prying out old seal
Half shaft. circ clip left on. Is at threaded end
Seal removed. note: Oil does not come out and unit is full. also note main diff studs have been put back in to stabilize diff for seal Removal and new seal placement
New seal 3/4 way in
Pounding Half shaft in. circ clip holds it in
Tie rod
Install new seal
closer view
Tie rod removed
new seal
prying out old seal
New seal 3/4 way in
