PASM error, stuck in sport mode
Hello all,
Has anyone had any experience with this error? This error displays as soon as I roll a few feet. The PASM error displays and suspension is in it's stiff mode. Hitting sports mode button gives a sports error.
I have a 2006 C4S with H&R lowering springs. I've read it could be cable, struts, etc.
Has anyone had experience with this? What did you replace to resolve it and what was the cost?
TIA
TIA
If one of the PASM shock wires is backwards or disconnected it will throw an error and default to full stiff.
Did it work fine then all of a sudden start throwing this error (check for loose connectors)? Or did it start just after installing the H&R lowering springs (check for connectors installed backwards)?
