PCM aux/usb/ipod input options disappeared
Plugged in my iPhone into my 09S with base radio. Has the iPod/aux/USB ports in the center console. The menu on PCM to select which input was accessible at that time and I selected to show USB which then would not play music for some reason. So I grabbed an aux cord and tried to find the menu to allow AUX as an option on the PCM but cannot for the life of me get that to come up as an input option again on the PCM. Just says FM/AM/CD. Any idea how to get to that menu again? Would like to play Spotify through the aux. If I plug an old iPod Nano into the iPod port, iPod does come up as an option automatically. Aux doesn't however.
I just recently had to do this on 997.2 that I purchased last month. I guess the previous owner never used the Universal Audio inputs.
Since the car is at home, I can't verify the steps again, but I believe that you have to select "DISC" mode on the PCM and then press the "OPTION" button. This should bring you to a screen that allows you to select which inputs you want to show up as available. Just tick the AUX box and then it will be available.
I'm hoping that I'm remembering this correctly and not skipping a step!![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
-Chris
-Chris
-Chris
-Chris
DRVN1 (01-15-2021)
Hi , I'm new to this forum but just wanted to say thank you to silver stealth for the 'fix the annoying disappearing Bluetooth solution '....it worked ...think it was when my son wasbutton mashing trying to get his phone to work with the 'stupid PCM ' lol ...and he wonders why I don't let him drive my Cayenne ...thank you
-Chris
-Chris
I got the same weird issue. Worse still, I can not see the AUX checkbox in this option screen, only AUX BT there. Meanwhile, jukebox/iPod/usb were disappeared in media screen as well. Do you have any other idea?
This!!! When I added a Sat Radio Board almost a year ago (requiring licensing and PIWIS) I lost the Aux input and purely by experimentation found I needed to insert a CD to "tickle" the PCM back into offering the Aux feature.
