DSC V1 question
Just installed my new DCS V1
I have a 2009 997.2 C4S Cab.
When I put the car in sport the PASM stays in comfort mode , where before when i hit sport mode the PASM went into sport/stiff mode. I can always hit the PASM button to getit into sport mode.
Also when i put the car in Sport Plus mode the PASM turns to Sport but you can not turn it back to comfort mode unless you put the car in standard or sport mode.
Just checking if this is right
Got mine just a bit ago. No manual to explain operation. PASM light tends to come on when I start the car. I believe this is based on whether it was on when I last shut the car off. I haven't noticed a problem shutting it off in Sport +, probably because the idea hasn't occurred to me.
The DSC box controls the PASM (shocks) only, and it remembers your last setting between power cycles. The Sport button controls the engine/throttle maps. In a 997.1 it does not remember the last sport settings between power cycles.
If you truly have an early version 1.0 DSC box, you can get the firmware updated to the latest for free, just pay shipping. Contact Tom and he'll hook you up. Put your old OEM box back in for the few days to ship the DSC one out and you will be amazed at the difference in handling.
