Why am I seeing carbon soot from my exhaust
I recently installed a Fister muffler along with a shark werks bypass. I have noticed carbon soot on my rear bumper since the install. Trying to determine why this is and how can I stop it.
Basic Sponsor
Not unheard of when you've eliminated a muffler and replaced the rest with higher flow ones. Less restriction for the carbon to make it's way out the back of your car, same with condensation build up. Every time I start my old Z28 after it's been sitting with straight pipes I coat my garage door and floor with some wet grayness
Porsche Performance Specialist
John@Fabspeed.com
215-618-9796
Fabspeed Motorsport USA
155 Commerce Drive Fort Washington, PA 19034
www.Fabspeed.com
John@Fabspeed.com
215-618-9796
www.Fabspeed.com
Watch your oil consumption. I suspect you are worried about bore scoring and the resulting blow-by.
As you watch, think about ensuring you boil off water in the oil by running the car hot for a while before critical measurement
Peace
Bruce in Philly
Peace
Bruce in Philly
Stock ECU usually can compensate for muffler/exhaust 'upgrades'. Not to be an alarmist but soot on bumper is pretty extreme imo. Be especially careful if it is one side. Bore scope is your friend if you have concerns.
Since reducing restriction in my exhaust system (with Fabspeed center muffler x-pipe) and doing Fister mufflers I'm seeing carbon soot on my garage floor at the rear of the pipes, as well. Nothing on the bumper or anything though. Sound and power is worth it though :-)
Remember too there is 1 possibly two converters (per bank) between the engine's combustion chamber and the exhaust pipe outlets and rear bumper cover. If there was an excess of soot present this could be as much a reflection on the performance of the converters rather than the engine.
For every gallon of gasoline the engine produces around 19lbs of carbon mostly in the form of CO2 but there is some carbon in solid form (soot) produced, too. Every exhaust outlet I see -- mostly my own cars but other cars in parking lots -- are black with soot.
Like I like to remind Porsche owners: Soot happens.
My Boxster doesn't seem to collect much soot on its rear bumper but my 996 Turbo does. Its aerodynamics are better and there is a much more pronounced low pressure area created behind the car -- to help the air forced in through the engine compartment lid exit out from under the car and to help pull air through the intercoolers -- and the Turbo rear bumper cover shows soot. Also, it is hard to distinguish soot from tire/rubber dust of which there is a lot on the roads.
Absent any signs of trouble from the engine or a CEL I'd not worry about a bit of soot on the rear bumper cover.
Post pics. Evenly distributed soot is the lowest of low concerns.
How the tips are positioned can matter. But more likely that some shaking and vibration from the install surely loosened up some soot from the exhaust pipes that stayed put.
If you know what an Italian tune up is, then go forth and do that. If you don't, then shame on you!
(yes, I sold my 911S and miss this placed briefly. lol)
Kappa, I will confirm this is completely normal on the 997.2's if you go to a bypass pipe AND use a modified gundo/fister cans. The residue you are seeing was normally caught in the side and center mufflers. I've had this issue on every DFI car that I've substantially modified the exhaust on. Get a good coating of wax on the bumbers and it wipes off easily.
Hmmmm.....interesting. Maybe....but there are much more likley explanations.....starting with something as simple as the inevitable oil burn off upon starting an a/c flat six.
Anybody’s 2.2, 2.8, 3.0 or 3.2 smoke upon start up? Happens with the healthiest engines. Height of oil reservoir seems to be a design flaw. Gravity will win every time w/o a back flow restrictor.
Id start there if no white smoke while driving the car
My car has carbon buildup on the exhaust tips, too. I have Fabspeed intake and exhaust and custom ECU with a tune. It runs rich for about 30 seconds, when it's cold. No big deal.
As you drive around or walk through a parking lot survey the exhaust tips of various cars (even new ones). You'll see soot a lot. Personally I think there's too many reasons to contemplate, but DFI engines, turbocharging, factory ECU settings and even different fuel formulations could be in the mix. I see soot on the rear end of my '09 C2 (DFI engine) regularly and not as much on wife's '07 MB C230 (port injection).
