You can not start the engine if your foot is not on the brake and lever is not in P or N.
Double check your brake switch one more time, maybe the switch is OK but it is not properly seated?
If you don't press the brake and switch on the ignition, the engine oil measurement should cycle.
Changed the brake light switch and still have the same problem. Put it on the piwi but there is no option to cancel pushing the brake pedal to start the engine
