Pcm3 on a 997.1, can it be
997.1 have the pcm 2. Would like to put the pcm3 to make it look originally. Can this be done?
There is a thread in here.....that goes to a UK 911 forum where its been done. So yes. It popped up in here a few weeks ago. It takes skill and patience.....not a simple thing to do and no kit. You have to source all the bits and pieces.
I don't think it's worth the headache. Dynavin makes a PCM replacement with an OEM look which will be a lot cheaper and has more features.
Tim (monster) in the U.K. Has done it to his car. Based on my discussions with him you need
-pcm3 unit -997.2 Bose amp -activation codes for pcm (very difficult to acquire from) -Lower air-con/climate control unit ONLY from a 2009 turbo (the one with 997.2 pcm with 997.1 rear end and metzger engjne - needless to say very rare) in order to get he air conditioning to function properly on a 997.1 car. Tim will likely chime in when he seems this thread as he's super helpful with everything. |
wow this lookd intimidating... yah let wait for tim to chime in and see what he has to say with the idea
1 Attachment(s)
Ha, Ive just been prodded by Michael!
Yes it can be done, I have a 2005 car and have installed it in mine and a few other peoples in the UK now. Everything works including the AC. Its a fiddly project but if your practical it can be done. Activation codes are needed to get certain PCM functions working, but there are ways of reliably obtaining these. Michael has listed the main items needed, there are other smaller things needed in addition such as the later 997.2 PASM button unit, an interface loom to connect the PCM 3 up to the original wiring loom in car, 997.2 GPS antenna cable and then wiring for the iPod function in the arm rest and the bluetooth handsfree kit. If anyone wants to give it a go I can talk them through it, or fire away and ask question and I''ll answer them on here. Here is a pic of mine all installed and working. |
Pcm 3 en 997.1
[font][font][CITA = monstruo1; 13881694] ¡Ja, Michael me acaba de empujar! [/font][/font]
[font][font]Sí, se puede hacer, tengo un automóvil 2005 y lo he instalado en el mío y en algunas otras personas en el Reino Unido ahora. [/font][font]Todo funciona, incluido el aire acondicionado. [/font][font]Es un proyecto complicado, pero si es práctico, se puede hacer. [/font][font]Los códigos de activación son necesarios para que ciertas funciones de PCM funcionen, pero hay formas de obtenerlos de manera confiable. [/font][/font] [font][font]Michael ha enumerado los elementos principales necesarios, se necesitan otras cosas más pequeñas, como la unidad de botón 997.2 PASM posterior, un telar de interfaz para conectar el PCM 3 al telar de cableado original en el automóvil, el cable de antena GPS 997.2 y luego el cableado para la función iPod en el reposabrazos y el kit de manos libres bluetooth.[/font][/font] [font][font]Si alguien quiere intentarlo, puedo hablar con él, o disparar y hacer preguntas y las responderé aquí. [/font][/font] [font][font]Aquí hay una foto mía instalada y funcionando. [/ QUOTE][/font][/font] [font][font]hola buenas [/font][/font] [font][font]estoy haciendo la concesión a pcm 3 [/font][/font] [font][font]tengo todas[/font][/font] las piezas pero tengo algunas dudas me podrías ayudar con lo del amplificador saludos si me puedes ayudar te lo agradezco saludos |
Weird thread, even for 2017. Why would you replace one outdated PCM with another outdated PCM?
Originally Posted by jkoravos
(Post 16109003)
Tim, sent you a PM sir. |
Wouldn't it no longer be period correct if you change it to something that was never available in that car?
(Post 16112096)
Aha, I didn't know that they put PCM3.0 in the end of the 997.1 run.
Ayuda
Alguien me puede ayudar con el cableado del Pcm al amplificador
saludos |
If anyone wants a PCM 3 to do this, I have one pulled working from my 2010 Cayenne.
Help amplificador
[CITA = CELESTINO; 16108640] [fuente] [fuente] [CITA = monstruo1; 13881694] ¡Ja, Michael me acaba de empujar! [/ font] [/ font]
Hola buenas necesito ayuda para hacer el telar del Pcm al amplificador donde conseguir la antena gps y la clavija del amplificador son las cosas q no tengo claro la pieza del Pcm está claro y lo del clima ac lo tengo claro saludos y gracias |
