2010 997.2 C2S 60K Mile Service
Sorry for double post - I'm not seeing any of your guys mention the PDCC, which Road Scholars suggested I change. This is a very large repair dollar-wise it seems. RS suggested it should be changed at the 60K mile mark / every six years...any thoughts?
How do you have PDCC on a 997? LOL
PDCC was introduced with the 991. It's not a maintenance item, if it breaks or fails, the car is still good to go, you just have a PDCC that doesn't work. It's just like used shocks. They go bad over time but you can still drive the car forever on blown shocks.
FYI, I think I paid $90 or so at my indy to change the Serpentine belt (997.2). The car was having some coolant pipe replaced so I had them change the belt. I normally DIY simple stuff like, filters, oil, brake fluid, brakes. The belt was a Porsche belt, so it cost a lot more than the Continental belt you can get on Amazon for $30 or so.
My initial thought....
BTW, my 2009 has a pinhole leak in the power steering reservoir... it went dry once, I filled it and never had to add in the last few years. I see and cleaned up goop under the tank..... I think the interface between the tank and the metal housing is the culprit. I was going to replace the tank, but you have to remove a ton of stuff like AC and such.... forget it... for now.
Peace
Bruce in Philly
