RennStand - The New Jack Stand for Porsche Enthusiasts
#31
Thank you for the input!
#33
This product is a "one-lift" stand, so you do not have to jack up the front of your PCar to get the jackstand under the rear. So, I see this jack stand concept as an alternative to the Jackpoint Stands, which are $300 per PAIR! If you don't need to jack up all four ends, you can make do with just a pair of these stands and a floorjack.
I have a pair of Jackpoint stands and they are great. But they are wide when you are working around the jackstand but under the car. And you have to be careful when lowering the Jackpoint plate onto the jackpoint stand itself because the Jackpoint Stands are a two piece system.
This stand it also two piece but it appears you do not have to lower one piece onto the other. The stand attaches to the plate with out having to lower the plate onto the stand. This product also looks like it is more flexible than even the JackPoint stands when it comes to floorjacks and if they can design some height flexibility into the entire system, it seems like a great concept improvement.
I also have some Esco 3-ton 10498 stands, which are the greatest stands on the market for a two lift system. About $100 a pair, but again you will need a floorjack to lift the front end "real high" to get the floorjack under the rear, or vice-versa.
I think the new one-lift systems are safer not only for the grease monkey under the car, but probably easier on the car itself.
(Disclaimer: I have no business relationship with the proposed jackstand or the owner of the proposed jackstand.)
Also a great observation about the stands taking up limited space under the car. They're more open in design as well, allowing work through if necessary, and I often use that space in between the bases to keep tools, bolts, screws, etc. together while I'm under there.
We are planning to improve the height flexibility as well. The prototype in the video has 3 height settings ranging from 11" to 15" at maximum, but we intend to broaden that range in the production version.
Very much appreciated!
#34
I look around my garage/shop/hanger and I see lots of 'expensive' support equipment. You wanna see expensive jack/stands, try buying some aviation ones. With those I am jacking up something worth what a 918 is, so not much compromise made on quality there. If we want our products to be 'local and of good old days quality', we most likley will have to pay a premium. I understand and accept that, but I also understand each of us has various circumstance that dictate what we do. If baby needs a new pair of shoes and daddy needs (wants?) new jack stands something may have to give. No babys in this house, so daddy will get his 4 new automotive jack stands.
I also have a couple of motorcycle lifts, one made in China, that is mostly a piece of crap. When I use it I have to add in additional jack stand supports just to be safe, then they get in the way. Then a US made one that cost me about 3 times as much. That one I would sleep under, once the internal safety bars are locked in place. Funny they both have labels rating them each at 1000# capacity the US one I believe, the Chinese one I think might be out a factor of 3, the same factor as the cost difference?
Thanks for the post!
#35
My current aircraft is a land only low wing design, the jack stands are basically a standard hydraulic ram with a sturdy 3 point base and an locking system. I could well see where your basic design could be adapted for an amphibious float plane. Could you make them of an aluminum alloy to help keep the weight down? Weight is a big issue in the aircraft world.
#36
#37
Thats cool, once you get the automotive side figured you got the avaition folks to work with. As an aircraft owner, I am a bit more numb to any sticker price shock. FYI, the biggest Amphib that I am aware of is the Cessna 208 Caravan at 8850 lbs gross weight.
#38
I believe we can egineer one to accomodate that weight, and I appreciate you letting me know. I like the idea of building something for the aviation commmunity at some point
#40
^^^^ditto^^^^
I'm concerned about the amount of parts that go into this. What are the locking pins made of? What if they break? What if the locking/insertion rings shear? How sturdy are those bends? Any failsafe mechanisms? Not trying to **** on your product, just some concerns.
#41
The question I have is in regards to the universal application of these stands. In order for it to work, the jackpoint has to be far enough away from the tire so the stand leg clears it.
#42
Just to give you an idea of how strong the current pins are, they are 1/4" steel and each is in double sheer and capable of sustaining up to 1.9 metric tons of force per pin. In addition, keep in mind that each pin will only bear half the weight of whatever each stand is supporting. So you would have to load 4 metric tons on EACH stand before you approach pin failure, while the complete pair of aluminum stands is only rated to 2 tons. That gives you a safety factor of 4 for each pin, and the new larger pins will naturally exceed that.
The durability of the design has repeatedly, and will be again, subject to testing. Simulations of the current design were done by an aerospace engineer from Embry Riddle Aeronautical University and were conducted both on level ground, and in other more extreme situations that we would never recommend our customers placing our stands in, though they passed those tests as well. This was conducted on our aluminum version, and the results of the testing demonstrate the design's ability to exceed the ANSI requirement for a safety factor of 3 or greater, which gives each stand a safe load rating of 2,000 lb, or 1-ton. , so you could imagine how much stronger they are in full steel or as an aluminum-steel hybrid which is likely what the production version will be.
When the production version is finalized, it will also be subjected to simulation and practical testing to meet ANSI standards, but also impractical testing with the sole intent of destroying it to determine how much it can actually endure before it fails.
Guys, we put safety above and beyond the other attributes of the design, and we went to Embry Riddle for help, which is the world's best aerospace engineering university on the planet, bar none. The stands may look simple, but months went into engineering and testing. I wouldn't put anything out there that I wasn't willing to let my kids sleep under.
Again I really appreciate the questions, and for giving me the chance to talk about our safety standards a bit
#44
I have never heard of a jackstand pin breaking, however in standard tubular jackstands they pass through the tube several inches apart, so the force is applied at two points about 3" apart, so the likelihood of a pin shearing at both points simultaneously is extremely low. In this design the cross section is much narrower, so the force on the pin is more concentrated. Employing a U-shaped pin and double holes would mitigate, as would using an alloy with higher strength, but the simplest and cheapest would be merely increasing the diameter of the pin.
You're correct about the pins being in double shear. The current pins are capable of sustaining up to 1.9 metric tons of force per pin. With each pin only bearing half the weight of whatever the stand is supporting, you would have to load 4 metric tons on EACH stand before you approach pin failure. Currently a complete pair of aluminum stands is rated to 2 tons. Still, based on feedback we've been receiving, we are intending to put larger pins in the production version.
I appreciate the input and the question!
#45
Makes sense how you configured them to anticipate jackpoint placement!
As for the pins, increasing the diameter is certainly the most straightforward means. Testing is excellent. Remember, there is a difference between stress and force. Force is mass X acceleration, i.e., what the pin is subjected to when the jack is withdrawn and the weight of the car descends upon the stands. That varies not only with the weight of the car, but also how quickly the car is lowered. Once the car is resting on the stand, the pins are no longer subject to force, and modulus of elasticity becomes more relevant than shear strength.
