Wheel Offset Narrow Body C2 997.2
Old 12-27-2016 | 02:08 PM
myw's Avatar
myw
oem finish or have they been refinished?
Originally Posted by gdclnfn
I purchased 2 off eBay for the same price from 2 different sellers in NY. $487 shipped (each).
Old 12-27-2016 | 04:10 PM
gdclnfn's Avatar
gdclnfn
"Remanufactured" OEM wheels. 2nd is en route, but the first one was a perfect match/excellent shape with no signs of repair, etc.
Old 12-28-2016 | 06:53 PM
myw's Avatar
myw
awesome, let us know how it looks and compares. I'm assuming you're buying the second remanufactured wheel from the same seller/wheel refinisher.
Old 12-29-2016 | 03:53 PM
Iceter's Avatar
Iceter
Kellen mentioned increased road debris kick-up, and he's correct. I put 15mm spacers on my NB wheels and went to a 305 width rear tire. I have almost the same reveal as your car at the rear now.
I have noticed much more junk on the rear of the wheel opening after going to the wider tire and spacer, as well as ALOT more water and mud splash around the entire perimeter of the wheel opening.
I found it a small price to pay for a much better look.
Old 12-29-2016 | 04:08 PM
Mumbles's Avatar
Mumbles
I just installed my new rims with turbo body offsets with a 295 tire. The rear tire bead finishes flush with my rear fender. Perfect.
Old 12-29-2016 | 07:55 PM
myw's Avatar
myw
Old 12-30-2016 | 11:08 AM
Mumbles's Avatar
Mumbles
Originally Posted by myw
Without your help it would not of been possible
Old 01-08-2017 | 09:23 PM
lurchphil's Avatar
lurchphil
I just installed the following wheels on my 2012 997.2 Carrera S:
Fronts: 8.5 x 19, 56mm offset, 997.362.156.05
Rears: 11 x 19, 51mm offset, 997.362.162.02
The tires are Michelins 235 35 19 and 305 30 19. They fit perfectly and greatly improved the appearance.
Old 01-08-2017 | 09:44 PM
myw's Avatar
myw
nice, lets get some photos
Old 01-08-2017 | 09:58 PM
Jack667's Avatar
Jack667
I have 50 offsets on rear of my car, with 19x11 OZ Wheels. They look great, and they've been on for 6.5 years with no issues
Old 01-09-2017 | 10:53 PM
8202632's Avatar
8202632
I ordered 10mm for front and 15mm for rear from ECS. Very pleased with the more aggressive look! I have the ECS spacers also on my rs4 and cayenne. I find myself looking at so many cars on the road thinking "man, that car needs spacers!!!" Think ANY Toyota Camry!!!
Old 01-10-2017 | 03:26 PM
vintage911's Avatar
vintage911
I run BBS wheels in the turbo offsets on my narrow body C2S. I only have slight rubbing on the right rear on large bumps, but I am pretty low. I'm running just over 2 degrees of negative camber in the rear and a 7mm spacer up front (not sure on the camber in the front).
This is the way to go in my opinion as the narrow body offsets are pretty weak and don't look right. Just my $0.02.
BBS LM169 19x8.5" +50 with 235-35-19 Michelin PSS
BBS LM199 19x11" +50 with 305/30/19 Michelin PSS
mondo74 (10-12-2021)
Old 01-10-2017 | 03:30 PM
myw's Avatar
myw
how did it go with the other rear wide body offset wheel?
amazing stance. personally, if i ever lowered my car, i would likely go back to 295s to minimize the chance of rubbing.
Old Today | 11:04 AM
Hornet_312's Avatar
Hornet_312
Cruisin'
Sorry, this is an old post, but getting new tires for my 997.2 C2 and thinking of swapping wheels while I'm at it. Do you have any pics? Thanks.
Old Today | 12:46 PM
Risto's Avatar
Risto
I’m in the same spot. Just ordered 19X9 ET50 (235’s) up front and 19X11 ET 50 rear.(295’s) Still have a little time to change my mind.
Want them sitting flush to fenders but not poking out. Would rather they sit a couple mm inside than poke out. Also not sure if I should go to a wider rear…seems like a lot of people move to a 12 inch rear.
Quick Reply: Wheel Offset Narrow Body C2 997.2
