991 GT3 wheels on a 997 GTS?
What are the widths and offsets?
Edit: did the leg work for you
Rears:
GTS 19x11 et51
GT3 20x12 et47
Compared to your existing wheel, this new wheel will have an inner rim which is 8.7mm closer to the suspension strut. The outer rim will poke out 16.7mm more than before.
Rears:
GTS 19x11 et51
GT3 20x12 et47
I did some detailed analysis on willitfit.com
Fronts
997 GTS 235/35/19 8.5 wide ET 56
991 GT3 245/30/20 9 wide ET 55
Rear
997 GTS 305/30/19 11 wide ET 51
991 305/30/20 12 wide ET 48
Looks like this will all work out. Anyone know if the CL itself is the same between 991 and 997?
Sent from my mobile device
Fronts
Rear
