Durametric not clearing airbag light codes randomly?
Hey guys,
Have a 997 with seats and a steering wheel inside.
Was switching out the steering wheel the other day and when starting the car noticed the air bag light now won't go away.
Pulled it up on the Durametric and these were the codes throwing.
Seems odd as the seats have never had a problem since i installed, i unplugged and replugged in the plugs for the seat airbag setting, nothing changed.
Durametric clears the airbag faults which turns off the airbag light. But if the underlying problem is still there it comes back on. Since you are seeing airbag errors on both seats look at the common areas - the airbag control unit itself.
Any chance you had your center console out recently? Like for a shifter or radio upgrade?
Check the connection to the airbag control unit. It's located in the center console area under the PCM stack. You can usually see it by removing just one of the side trim panels to the center radio area. The main harness connected to the airbag control unit goes out to the driver's thorax airabg, passenger's thorax airbag, belt locks on both sides (perhaps your driver's side is disabled), and passenger's seat weight system - all the errors you are seeing.
I'd also verify the steering wheel airbag connector is inserted properly since this was a recent change on your car. It can be tricky looking like it is seated correctly when it is not.
Where does the buckle ground? There's only two wires that come out of it which go to the airbag module.
Everything stock plugged in, still pulling codes. I think my Durametric system may be messed up. Updated and still issues so i'll head to my friends shop with a PIWIS tester
