Aux / Bluetooth Iphone Music for 997.1
hi folks,
i have 997.1 . i want to listen to my songs from my iphone using either bluetooth or aux. doing quick search suggests a few options.
1. porsche oem ipod / aux from suncoast (con: high price) (http://suncoastparts.com/product/OEMKIT.html)
2. transit blu (pro: cheaper)
3. tooki
4. dension
5. FM transmitter (pro: cheapest solution, con: interference / quality )
i have the pcm with phone buttons on the left and navigation.
some posts are years old. wondering if someone has recently installed any of this. maybe a better product in market now. what are pros and cons.
any help would be appreciated.
3. tooki
4. dension
requires wired connection, USB will not charge the phone so need to use the 3.5mm plug for music AND the lightning cord to the cig lighter as the power outlet in the cubby is lost with the interface install, and does not have a mic for handsfree phone
3. tooki
IIRC this is primarily for handsfree phone and will only play through one set of speakers, not all
4. dension
Expensive, has the best on-screen display, but pointless to me in a 997.1 because of no touch-screen. Also read it has the most glitches and difficult to download firmware updates.
Unless you live in an area where there are plenty of clear frequencies not nearby strong ones, none of these are very enjoyable to use. Strong stations nearby will step on the transmitter at various times of the day.
3. tooki
4. dension
Well they sell the unit their for $199 installed, but they will meet any authorized dealer price. Amazon.com is the seller and they recognize them. So they will Match the $75. They will tell you that they can't install it for that though. I then said to them "if I bought your item WITHOUT installation do I get a discount"? They said no. So I told them then they're really not charging for the install. They then said they would do it for $50. I argued a bit more and they dropped it to $25. You may have to pay the $50 but still a great deal. You may need an antenna as well for the unit which they sell for $18.
Locating the mic and control button are a matter of personal preference. The button attaches with double-stick, I stuck it to the volcano-gray trim piece under the cluster just left of the center stack, because it's almost invisible there. I can find it instinctively and it's an upward press, which I use my knuckle. The mic I didn't like how it looked atop the A-pillar, so I routed it past the steering column, up and around the oil temp guage and analog speedo, and nestled it deep between that and the tach. Well-hidden, and sits right in line with my face, gives great call quality. Only downside it picks up the turn sig clicking more than if it were on the A-pillar, but it picks it up some on the pillar too so it's not a huge negative.
One negative about the Tranzit is you can only pair one device with it. Pairing a different device is easy using their iphone app, but it requires it to forget the other, so it's not as convenient for 2-driver households as units that store 2 or more devices.
HERE IS MY INSTALL and the rest of the thread will outline the entire procedure.
Mobridge is expensive too, just like Denison. The reasons that I like it are:
- It taps directly into the MOST ring and the sound quality is excellent.
- It offers high quality streaming bluetooth audio, with track information displayed on the PCM screen. I can use this for iTunes, Pandora, Spotify, XM radio, etc.
- It doesn't require any external controls; everything is done with the stock head unit controls. The installation is "invisible".
- It takes advantage of the telephone functionality of the stock PCM unit. I can use the phonebook function, favorite numbers, etc. Telephone numbers can be direct dialed using the keypad to the left of the PCM screen (I prefer that to a touch screen). Caller ID is displayed on the screen when a call comes in. The stock buttons on the PCM unit to answer and hang up are functional.
- It has been trouble-free, without glitches since I had it installed two years ago.
It's not the right choice for everybody, but it was for me.
IIRC there is a thread or maybe two on here outlining the install with pics. The hardest part was undoing the stubborn screws holding the PCM head to the stack. Beyond that it was a piece of cake, and I even soldered and used heat-shrink insulation on the power and ground wires because I'm not a fan of crimp-connectors for splicing into existing wires. In addition to the unit kit you'll need an antenna adaptor cable because the Tranzit comes set up for a Motorola connector. I think it's around $20.
tranzit blu all the way
disassembly of pcm , 2 cables to splice (power + ground) in addition to wiring the mic thru the b-pillar.
absolutely love mine.
I have the Dennison unit in my 997.1 Cab (which was installed in 2012 when I purchased the car). Very pleased with it.
Turned out to be a complete waste of money as I never listen to music in my 911! I'm always enjoying that Symphony in Flat 6.
Save your money.
Save your money.
