Cars, Cameras, & 3D Printing
I put together a video that goes through the process of designing and 3D printing a GoPro mount for the front tow hook receptacle on a 997. If you are curious how 3D printing works or want to see some video clips from that mounting location, give it a whirl.
Thanks, I'm glad you like it! I created the video to share what I've learned about camera placement (multiple views are ideal, but add complexity) and I felt insight into the design and development process may be interesting to Rennlisters. That being said, if you have a 3D Printer or have access to one, I'm happy to share the 3D files with you at no cost. Let me know either way and I'll help you out.
Unfortunately i don't have a 3d Printer. I did have a few fairly large positions in some 3d stocks, Voxeljet, 3D Systems and Organovo. Made a very big profit in a short period of time and got out before the crash. I thought 3D was going to be the next huge thing. I think it still may be too early. Anyway I have no access to one either. If you're selling these I'd be interested in one.
The hype was all about bringing 3D printing into the home, but the content side wasn't (isn't) ready. Nobody knew what to do with the things after they got them home, besides print out a bunch of trinkets. You can see evidence with companies like Makerbot (who sold at their absolute peak) refocusing on educators rather than consumers.
PM or email me your address and I'll send you a mount next time I run the machine.
Fantastic video! I have been fascinated by 3D printing (and Porsches) for a very long time. Is there any interface possibilities with sketchup? I have used that in the past to make templates for parts. Again, great video and thanks for making Rennlist an even better place!
I would buy one
please take my money
This is terrific. One of the issues with the popular Rennline tow hook GoPro attachment is that it is 15 deg off to the right just as you mention in the video.
Most DE and track groups require the installation of the front tow hook while in session and your solution doesn't account for this (at least not the one in the video).
Can you modify the 'sleeve' with the camera mount to slide over the Rennline and/or OEM tow hooks so a tow hook can still be used and we can remain compliant to our track group regulations?
that would be a great idea
I do not think a 3d printed hook would hold up to towing
My original plan was to use the factory tow hook as the securing means for the sleeve, but it doesn't have any straight flats, "stops" or other geometry that could be used to butt up against the sleeve. I decided it was easier to recreate that piece with the geometry I needed at the end rather than work with the organic curve of the tow hook loop. That being said, I'll take another look and see if there's a piece I can create that will fit securely against the tow hook's loop, and have a flat "stop" for the sleeve. Basically, it would be a 3 piece system.
Tinkercad is another free CAD package that is very easy to use, and is arguably targeted at non-engineers. Lots of schools use this package in their curriculum, and most kids 6+ can handle it with supervision.
No need for anything else.
Sleeve would have lengthwise slit running down entire top side. Texture the inner barrel of the sleeve for friction against the OEM/Rennline hook (most track guys I know use Rennline hook so more opportunity there). Inner barrel should be just slightly smaller circumference than tow hook outer circumference. Then the finger screw and nut on the GoPro would close the slit and secure the sleeve to the hook via friction.
I don't have a Rennline tow hook here for reference, do you happen to know the diameter of the main tow hook bolt, and also the diameter of the hinged portion that allows it to flip down?
