Fader control with 997 MOST HUR and aftermarket head unit
So I'm swapping my head unit out with a Pioneer unit. My car is a 997.1 with Bose. I'm using the MOST HUR 997 interface to retain the factory Bose amplifier. Took my time but finally got it working.
One issue though, the fader control does nothing. All sound for the front channels is send to front, rear and sub by the MOST HUR. Is this normal?
Does anybody have their fader control working with MOST HUR and an aftermarket head unit? If yes, what head unit do you have?
I spoke with a tech at Nav-TV, the maker of the MOST HUR device. There is no fader support. All speakers on the left side of the car are driven from the FL output of the aftermarket radio. Ditto for the right side of the car. Fade is setup with the OEM radio prior to installing the aftermarket one. This means fader control is static, not dynamic as expected.
See a similar thread I started over on 6speedonline for more details.
