997.2 PASM in 997.1
Old 08-09-2016, 07:16 PM
ECS
ECS's Avatar
Default 997.2 PASM in 997.1
Am curious if anyone has made this modification? One of the highlights of the 997.2 over the 997.1 was an improved suspension. Is it as simple as installing 997.2 PASM shocks and springs or should one be concerned with all sorts of other subtle differences in the 997.1 car vs the 997.2 that would make this change ill advised?
Old 08-09-2016, 09:03 PM
Supermode
Supermode's Avatar
When I was in the market before I bought my 997.2 C4S, I test drove both versions and found that the .1 had a stiffer ride with PASM on. Mine has SPASM and its a mucher stiffer ride than normal PASM on .2's. It actually reminds me a lot about the .1 ride. I never have it on unless Im on the highway. Its too much for the streets of Chicago.
Old 08-09-2016, 09:47 PM
Hella-Buggin'
Hella-Buggin''s Avatar
You're best bet is the DCS from TRP Racing. It will give you the Three axis (vs. 997.1 Two Axis) modulation and un upgraded PASM control module.
Old 08-10-2016, 10:44 AM
Tom@TPC Racing
Premium Sponsor
Tom@TPC Racing's Avatar
By changing to .2 shocks, springs, and even sway bars will not produce the exact same results as in .2 car because the commands for the level of stiffness to the shocks from the PASM module is different between .1 and .2 cars, and for different models and options. For example, .1 PASM Sport mode commands 75%, while .2 PASM commands 80%, .2 SPASM 90%, GT3 95% and so on... The factory PASM modules are coded for specific generation, model, and options so they won't function at all when its installed in the wrong car! It will display "PASM Fault" as soon as the ignition is turned on without even starting the engine.
Years ago, prior to DSC, I experimented with swapping PASM shocks, springs, bars, and then to Damptronic coilovers and then with different spring rates. Even gone as far as revalving Damptronics. While I was able to feel each change, the results were ultimately limited by the command to the shocks from the PASM module. I was able to work around some of the damper stiffness limitation to get the balance I wanted by using heavy sway bars like the TPC bars and by upping the spring rates. That was a lot of work! Now that DSC is available, the issue with damper stiffness commands is solved in a seamless manner.
If the shocks, springs, and sway bars are in good working condition then there's no need to change these items to exceed both the comfort and sport performance of that on a .2 car. Swapping out the PASM module with DSC module will do that. And DSC can be custom mapped by the user via free tuning software(with DSC tech support). .1 car requires an accelerometer since the factory .1 accelerometer is only 2-axis. Its 3-axis on .2 cars. In order to achieve 3D mapping on .1 car a 3-axis accelerometer is required.
If you must have original factory Porsche parts then the best you can do is swap to .2 shocks, springs. and sway bars for a portion of the difference in performance with 2D damping commands for .1 PASM module.
PCA National Instructor
TPC Racing stats:
2023 Porsche Sprint Challenge 992 Cup Am Champion
2023 Porsche Sprint Challenge GT4 Pro-Am Team Champion
2022 Porsche Sprint Challenge 992 Cup & 991 Cup Champion
2020 IMSA GT3 Cup Challenge 2nd Championship
2018 IMSA GT3 Cup Challenge 2nd Championship
2016 IMSA GT3 Cup Challenge Champion
2013 IMSA GT3 Cup Challenge Champion
2006 Rolex-24 @ Daytona GT Champion
2004 Grand-Am SGS Class Champion
Old 08-10-2016, 03:15 PM
ECS
ECS's Avatar
Wow, Hella Buggin and Tom-TPC. Great information. Thank you. I will look into DCS.
Erik
Old 08-10-2016, 03:56 PM
motopix
motopix's Avatar
TPC, will my 997.1 DSC module move right over were I to buy a 991.X car?
How about other P-models with PASM?
Old 08-10-2016, 04:43 PM
ECS
ECS's Avatar
Hella,
My one concern with such an active suspension system is that it will feel unnatural. Have you used it?
Thx
Old 08-10-2016, 05:14 PM
Tom@TPC Racing
Premium Sponsor
997 and 991 module are completely different. See image below.
991 DSC module have extras pins for factory ride height sensors data for Suspension Velocity tuning function and dynamic engine mount tuning.
We could develop DSC module for other p-car, but currently we are focusing on sports cars(Porsche sports cars, C7 Corvette, SRT Viper, Nissan GTR, Ford GT350), next is resto mods. Crossovers, SUV's, and sedans are not on our radar at this time.
Old 08-10-2016, 05:23 PM
Tom@TPC Racing
Premium Sponsor
Hella,
Thx
My apology for answering out of turn. There are no shortage on threads and individual owner reviews on the DSC module here on rennlist and on 6speed forums. The only thing unnatural about DSC is that the handling and stability is so good that its uncanny. The damping management on the current DSC 2-mode version is seamless.
Old 08-11-2016, 01:34 AM
Hella-Buggin'
Hella,
Thx
I haven't used the DCS unit but if you have pasmnyoure riding on a active suspension system already. One that's 11 years old. Think about whatnot would believe to have an 11 year old iPhone or laptop. I have a few friends with the tpc DCS unit and they like it.
Old 08-11-2016, 05:01 PM
ECS
ECS's Avatar
Thanks all!
Quick Reply: 997.2 PASM in 997.1
