PCM 3.0: I'm done with it. Will try to change it
Sound Quality? Amazing, absolutely amazing. No vibration of any kind, particularly because the rear subwoofers were replaced with 5.25 inch (same OEM size) but way much better construction, material, quality and power. You also will find lot of bass coming out from the doors (3 Way components).
In the other hand, the AMP was configured to get clean sound, with low gain...so no vibration and distortion of any kind. Remember the 997 cabin is quite small, so you don't really need a big AMP. What I really like of the Hertz is the fact that many P-Car owners installed before without issues (was recommended by CAI for a while) and has enough power to move 11 speakers (2 tweeters, 1 center, 2 upper doors, 2 lower doors, 2 rear panels, and 2 little subwoofers. I was not looking for high volume; I was looking a big clean sound stage, and I have a lot of high-volume as well. I'm very happy with the result.
Cheers,
T.
Cheers,
T.
