A little tailpipe anxiety - 997.2
I lefy my exhaust tips off when I changed from fabspeed pipes back to factory. one less item to ponder over, and less weight on the rear!
I like to give the car an Italian tune up now and again. some cars see too much stop/go and short trips which aren't beneficial to engine health.
my motto is: drive more and worry less.
I watch my gauges and keep fluids clean/topped off, otherwise I try
to enjoy what I have vs. what might happen.
one mechanic once said: "drive it until it breaks" taken with a grain of salt, this is one tac which makes some sense.
HAPPY MOTORING
HAPPY MOTORING
But what are you going to do if you notice one side more sooty than another? Demand a new engine? Demand a rebuild? If there is no warranty I'd require way more evidence that something was amiss before I'd put a wrench or pay someone to put a wrench to the car.
My advice is to ignore the tail pipe sootiness. You will of course monitor oil consumption as that's part of owning a car.
Then drive the car and give it reasonable servicing. Nothing you can really do if the engine is destined to score one or more cylinders unless you are willing to fund some kind of preventative/corrective rebuild of the engine.
BTW, the more time you spend driving the car the less time you have to spend on line and the less time you spend online the likely you'll have your already elevated paranoia levels increased.
It is a pretty July day. Get off line and go drive that car.
I think my concerns are reasonable, and thankfully some addressed the point of my post enough to get me to chill about it some. I'm not an irrational reactor that would demand my engine gets replaced because I have sootier left tail pipes. If nothing else, I thought the phenomenon was interesting in a generation of the car that supposedly has had the bore scoring issue resolved.
All I was looking for was some "yeah, mine's like that too" or "sh$t! you better keep an eye on that because that's not supposed to happen!!" I got neither, but thanks anyway for the valuable "life is short, drive a Porsche" life lessons
For clarification... the left tailpipes service the right bank's exhaust gases . The right bank is where scoring is more likely to occur. Some owners have found scoring by monitoring oil use and differences between the left and right set of tailpipes.
I think everyone is aware they get sooty... and that's not the OPs concern .
Nonetheless... paranoia is a bitch. Lol
I'd think it has to do with elevated engine temps which I guess has partly to do with rpms. You need to drive home faster
Purchased my car in march of 2006. Left tail pipe noticeably darker than right from the get go. At 3K miles, after I complained to dealer and Porsche Customer Satisfaction, A technician was sent from the manufacturer. Motor was bore scoped and leakdown test and plug inspection was performed. The findings were: "no engine faults found, no wear at all found. Motor is not even broken in."
10 plus years and 45k miles later my left side tail pipes are still darker than the right side. Driven properly the motor uses a qt of oil every 1200-1500 miles. This also has remained constant from day 1. Earlier I proposed an explanation for this. In the absence of bore scoring, consider 'random tolerance stacking' ie while within tolerances the values on one or more cylinders on one side randomly fall to produce a bank that runs richer or burns a bit more oil than the other.
There has never been any smoking, ticking what have you, no symptoms other than what I have described. The car is quite fast among other .1's.
Earlier in ownership I confess to losing a bit of sleep. At this point I can honestly tell you that at 7000 rpm in third gear it does not diminish the smile on my face one whit. This has been a good if a bit idiosyncratic car for me.
Cheers,
Gerry
Cheers,
Gerry
Sir Thomas Lord of All Mets Fans
Drive more, drive faster, drive harder. If there's a random, low probability failure in there, you want it to happen before not after CPO runs out. And, you'll want as many happy memories before then, in the unlikely event such a disaster occurs...T
Maybe I don't understand how the inside of the center muffler is built, but I doubt the pipes travel straight thru without having holes in them to facilitate muffling sound and as a result the exhaust from left and right get intermingled. If you have the center muffler bypass, then you might draw some conclusion if there is a big difference between left and right tips. Don't know what it might be!
Please follow the thread; address your .2 v. .1 concerns to them directly.
Capiche?
What is wrong with you man? The OP had a concern. it is not a valid concern for him or other.2 owners. This has been noted in this months 911 Euro mag. That is what this thread is about. Read carefully: .2 cars do not suffer from bore scoring. I went beyond your "setting others right" to address the issue. Get a grip. PM me if there is some past history between us that would justify this kind of nonsense on your part.
I would suggest that OP should not lose sleep over the pictures he posted. Thanks for the heads up.
