Slow engine turn over
Old Jun 30, 2016 | 10:18 AM
DC911S's Avatar
DC911S
You can check the voltage drop across the cable, and then decide if the cable is bad or its the starter. A good shop will do just that. But do it when its hot. Mine was fine when cold, when hot....nope. Power is volts x current.....When the voltage drops, and you need the same amount of power, then current draw goes up!
Old Jul 10, 2016 | 09:45 AM
w1234ale's Avatar
w1234ale
So does this same issue occur with the 997.2?
Over the last two weeks my car would start fine at home but the when I went to start it when the car was warm it has gotten slower and slower until yesterday where it wouldn't turn over at all and I had to get towed.
It seemed to me that the battery was not charging and maybe that there was a problem with the alternator but may be it is actually the starter.
Thoughts?
Old Jul 10, 2016 | 10:10 AM
motopix's Avatar
motopix
When it's the heat soaked starter, the car will still start just turn over very slowly. It never killed my battery but I didn't ever do more than 2-3 starts while heat soaked and out and about before the car sat long enough to cool off (about 15-20 minutes) and start up w/o a problem.
It sounds like you may have the heat soak issue but you eventually killed the battery and/or an alternator problem like you said.
Old Jul 10, 2016 | 10:19 AM
TCZ's Avatar
TCZ
I had the same issue. Mine turned out to be the starter. I had the cable replaced at the same time. Has turned over like a champ ever since.
