Surface rust in fender well. Should I be worried?
Looking at the photo is hard to tell what part of the body it is but it would appear that the Tailored Blanks are the only materials that are semi-finished.
Tailored blanks are semi-finished parts, which are typically made from sheets with different alloys, thicknesses, coatings or material properties. After joining, these will be subjected to deep drawing or stamping.
Tailored blanks were developed by ThyssenKrupp to make sheets that were wider than those made on available rolling mills of the time. These days, tailored blanks are used to make items such as door panels which are thick near the hinges and thin near the lock to withstand different types of loads or corrosion attacks. They are lighter and often cheaper than conventional sheets. Tailored Blanks are typically made from steel. Aluminium and dissimilar material tailored blanks are also available but less common. (Wikipedia)
With that little rust, I wouldn’t worry about it. If left untreated in CA, nothing will actually happen in your lifetime.
If you want, you can spray it with POR-15 metal prep that would convert the rust into a hard black surface and call it a day.
Big smoke - free car therapist
