Fixed engine squeel
Old May 14, 2016 | 04:50 PM
anewman's Avatar
anewman
For the first three minutes my 2008 CS2 (80k miles) would produce a faint squeak/squeal sound from the engine area. After too many other attempted "fixes", including belt changes, I finally solved it. It turned out to be drive belt rubber built up on the AC and Power Steering pulleys. Before changing to a new drive belt, I cleaned off all the pulleys with super fine sand paper (using a rubber wheel attached to a drill to spin the pulley while holding sandpaper in the belt groove). Problem solved. That was six months ago and has sounded perfect ever since.
Old May 14, 2016 | 08:27 PM
jchapura's Avatar
jchapura
Thanks for sharing. Great find.
Without this story, I would have thought that a build up of rubber would have increased friction - kind of like a race track...
