Misha vs Getty Design
Old 05-08-2016, 10:18 AM
BaileyII
BaileyII's Avatar
I drive a 05 997.1s. Please give me your opinion which is the best duck tail for my car. Thank you, Sent from my iPhone using Rennlist
Old 05-08-2016, 11:02 AM
Hilltopper
Hilltopper's Avatar
Originally Posted by BaileyII
I drive a 05 997.1s that was involved in hail damage. Please give me your opinion which is the best duck tail for my car.
Thank you,
Getty perfect both my 993 and 997.1.
Old 05-08-2016, 11:12 AM
Cloudspin
Cloudspin's Avatar
^ Same with my .2 C2S.
Old 05-08-2016, 11:17 AM
SoCal C2S
SoCal C2S's Avatar
Getty....it replaces the whole deck. I believe the Mischa is a wing insert and therefore has a crease where it meets the stock deck. Color matching might be a challenge as well, but a good body shop will figure it out.
Getty has a great mold and fitment is pretty spot on, however others have had issues. Mine was spot on with just a little blocking on the bottom of the deck.
If you go with Getty, get the harness and primer options as it will save on painting/install time. The primer service makes the deck "ready for fitment", not painting but really cuts down on the finishing time. The harness will allow you to keep your old deck complete if that's what you want. I bought a new fan and the various rubber snubbers with attachment hardware so I literally can swap back to stock with only the four main bolts and plug in the harness.
Oh..sorry for the ramble, get the Getty!
Old 05-08-2016, 11:49 AM
Hilltopper
Hilltopper's Avatar
Originally Posted by SoCal C2S
Getty....it replaces the whole deck. I believe the Mischa is a wing insert and there has a crease where it meets the stock deck. Color matching might be a challenge as well, but a good body shop will figure it out.
Not a ramble and the same recommendations that I have pm'd to several forum members. Additionally, you can turn off OEM spoiler speed signal indicator in the system.
Old 05-08-2016, 12:05 PM
Fined
Fined's Avatar
I'm going to be going with Getty in the coming months
Old 05-08-2016, 12:10 PM
SoCal C2S
SoCal C2S's Avatar
Yep....took my Indy all of 3 minutes to disable the spoiler message...and he didn't charge me!
Old 05-08-2016, 12:11 PM
mikes70
mikes70's Avatar
Can any shop with a ______(PCM? the machine/computer for Porsche only) turn off the speed signal indicator and OEM spoiler?
Old 05-08-2016, 03:39 PM
Hi-Arc
Hi-Arc's Avatar
I have a new Misha ducktail I will be listing shortly. Contact me if you are interested. I am going to stay with stock wing. Both MFG's make a nice ducktail. Misha is a lower profile and allows you to keep visibility of the stock third brake light. You will just need to remove your stock wing and mount in position vs entire decklid with the Getty. Both require the program change as mentioned. There are a few posts with nice pictures of member installs as above.
Old 05-08-2016, 05:17 PM
myw
myw's Avatar
getty, resembles closest to the oem 997 ducktail not to mention cleaner single piece unit.
Old 05-08-2016, 06:00 PM
Hilltopper
Hilltopper's Avatar
Yup!
Old 05-08-2016, 06:06 PM
slicky rick
slicky rick's Avatar
Piwis...
Old 05-08-2016, 06:52 PM
golfnutintib
golfnutintib's Avatar
i went with the mischa unit but the getty's are good too...above info is all correct, getty is integral unit, mischa goes on top of oem decklid (i liked that it allows me to keep my original decklid, lettering and chmsl)... if u compare the pics u can see the getty kicks up an inch or so higher, blocks the oem chmsl
...and turning off the motorized wing button is no biggie... dealer did it in 5 min no charge
Old 05-08-2016, 11:29 PM
gonz911
gonz911's Avatar
Subscribed...
Old 05-09-2016, 12:46 AM
myw
myw's Avatar
your car looks great from all angles.
Quick Reply: Misha vs Getty Design
