3rd brakelight issue
Old Apr 21, 2016 | 11:11 AM
Little Green's Avatar
Little Green
Default 3rd brakelight issue
So this morning I get a message on my dash on the 3rd brakelight for my car. I had someone check and it comes on no problem. Any ideas on what it could be since it still works. faulty sensor somewhere?
Old Apr 21, 2016 | 12:33 PM
997_Toronto's Avatar
997_Toronto
Fuse? Or a short that is causing the error to display?
Old Apr 21, 2016 | 01:45 PM
jhbrennan's Avatar
jhbrennan
Did you check it with the spoiler up? You have two center lights.
Old Apr 21, 2016 | 02:08 PM
Little Green
I removed my spoiler two years ago for a fixed wing so I don't have the 4th brake light
Toronto,
I will check but the light works. Just strange
Old Apr 21, 2016 | 04:26 PM
997_Toronto
The reason I suggested fuse or shorting is because if the fuse is on it's way out it might malfunction. Shorting due to metal touching the wire that causes the error when the contact happens (due to power leakage) but the light still works.
Toronto,
