Best lug nut paint?
Old Apr 5, 2016 | 12:38 PM
stairmasterman911's Avatar
stairmasterman911
Default Best lug nut paint?
My lug nuts look awful. As does the hub. Is there a particular paint that is better for this? Seems like a great DIY for a simpleton like me. Thanks for any input.
Old Apr 5, 2016 | 12:57 PM
jhbrennan's Avatar
jhbrennan
Bolts...but we all know what you meant. I think USMC_DS1 posted a DIY on how to clean - not sure if he discussed paint but you can try a search,
Old Apr 5, 2016 | 01:08 PM
nwGTS's Avatar
nwGTS
Rustoleum or duplicolor. Both are great. You can go fancy but why? You'll need to touch them up yearly depending on your driving habits anyway.
Old Apr 5, 2016 | 01:56 PM
OKB's Avatar
OKB
they all look awful, they always will. get chrome
Old Apr 5, 2016 | 02:41 PM
BIG smoke's Avatar
BIG smoke
Texas? You don't know what rust is. I'm with nwGTS, in salty Chicago. As to the above chrome comment, it also depends on who is working on your car. A garage that Hammers everything on and off with air impact guns? Nothing is going to survive that.
I'm tremclad/rustolium, wire wheel when needed.
Hand thread, and cordless for me.
File Type: jpg
File Type: jpg
File Type: jpg
Old Apr 5, 2016 | 04:39 PM
Ynot's Avatar
Ynot
Yep, got a spray can of Rustoleum at home depot and spray away. If you don't take them on and off all the time, the paint wills stay, otherwise it's just as easy to spray them again.
Old Apr 5, 2016 | 06:44 PM
Lvt19672's Avatar
Lvt19672
You guys need to sand them down a bit and get them nice and smooth before primer and paint. Also never use an impact wrench to loosen or tighten lug bolts!!!
Old Apr 5, 2016 | 09:10 PM
Neb's Avatar
Neb
I used plastic dip on my last set of lug nuts, held up well after 5 years. Just have to be careful with the sockets.
Old Apr 6, 2016 | 06:48 AM
Troy997.1's Avatar
Troy997.1
I went with titanium
Old Apr 6, 2016 | 09:36 AM
DB's997's Avatar
DB's997
Those look like lug nuts, not bolts!
I have bolts on my 997, had them on my previous 996 as well.
Very confusing! I thought all 911s had the same wheel bolts.
Maybe there are holes cut in the cardboard with the bolt ends sticking thru!
Duh?
Old Apr 6, 2016 | 11:36 AM
jhbrennan's Avatar
jhbrennan
Duh?
He made a DIY paint stand to hold the bolts while spraying the paint.
Old Apr 6, 2016 | 12:11 PM
Mbiondo's Avatar
Mbiondo
Correct, but he ruined that nice cardboard box in doing so. Such a shame!
Old Apr 6, 2016 | 01:54 PM
Carmichael's Avatar
Carmichael
Damn, I'm in Chicago, too, and my lug bolts don't look that bad.
Old Apr 6, 2016 | 02:21 PM
robh75's Avatar
robh75
you can also get black lug nut caps for less than 20 bucks on amazon
Amazon.com: (20) 17mm Black Lug Nut Lug Bolt Cap Covers + Extraction Puller Tool ~ Perfect Fit for All Mercedes: Automotive Amazon.com: (20) 17mm Black Lug Nut Lug Bolt Cap Covers + Extraction Puller Tool ~ Perfect Fit for All Mercedes: Automotive
Old Apr 6, 2016 | 02:27 PM
fresh-popcorn's Avatar
fresh-popcorn
How about Powder Coating?
For small items like Lug Bolts using a cheap toaster oven is large enough.
