H&R Swaybars - what's your setting?
Second softest from the end.
At one point I was planning on adjusting it to other holes to see if any of the other setting was better for me. But then I got the DSC box. No need to make any more adjustments on the sway bar. The DSC box dialed in my suspension the remaining amount I wanted.
I just want to add that the sway bar settings are one component of many and the setup of the other components in your suspension will affect how you tune your stabilizers. So, even though two cars may have the same setting on the sway, the entire alignment package needs to be looked at to get the correct picture of how that setting will affect handling. It s always best to set it at neutral until you drive the car at speed to get a feel for how it reacts to your driving style and road surface. My 2c.
