997.1 v 997.2 motor mounts
Is there a difference between 997.1 and 997.2 motor mounts (other than the active for the GT3/RS)?
Wevo and Rennline do not list a distinction suggesting all for 997 are the same.
http://www.rennline.com/Tuneable-Sem...oductinfo/M18/
Wevo lists as 997 up through 2008 (997.1). Either they are not compatible with the 997.2 or Wevo simply has not updated the page to include 997.2
http://www.wevo.com/Products/Chassis...gineMounts.htm
I'm looking to buy SS mounts for a 997.2 GTS.
db
db
The 997.1 and 997.2 part numbers are slightly different - 997 375 049 04/06 and 997 375 049 08 respectively, suggesting (to me, definitely not an expert) you should be fine.
Yes the .1 and .2 mounts differ ever so slightly, but in terms of fitting our semi solid mounts the only difference is on a .2 you will use the hex nuts we provide to secure the mount to the engine carrier instead of the factory close-ended nut. .1 already uses an open-ended nut so you can either reuse that or use the included part.
