Ruh Roh - dealer left an upsetting note regarding catalytic
Shouldn't even need to raise the car. Just stick your phone under and take a pic of each side. It will be obvious if they have been impacted because you'll see scrapping on the pipes.
The GTS just sits a little too low to get a good pic.
Thanks for posting that pic. I'm going to ask the dealer to clarify and see if they can get it up on a lift and take a photo.
Hope this all works out for you.
I saw an episode of one of the Sunday muscle car shows recently that dyno'ed a built American engine, and then they proceeded to progressively beat the headers ugly. They dyno'ed after each "assault" and there was no degradation in hp or torque even after they were substantially crushed. Their conclusion was 'don't worry if you bang them up to make them fit'. It was amusing to watch, and if you check the show websites (part of that Power Block Nation series) it is probably available on-line.
It's long but will educate:
Just FYI: These "ugly" headers are actually made using the latest tech called hydroforming... but they only started doing this in the 997.2 models.. These are harder to engineer but I guess that's one of the things we pay for in Porsches. The pipes look crushed but are engineering that way to fit better while maintaining certain pulse-tuning lengths. Despite intuition they have the exact same effective diameter all of the way down even though the pipes vary in shape. The bottom line is there is no constriction (one the 997.2 S/GTS models at least, not sure about non-S).
For OP: Of course, if your car is a 997.1 or they were actually crushed by some incident that is another story. As stated by others, we can advise if you can get clear photos to us. Sometimes the service reps really don't know what they are talking about. When I first took in my PDK to get the clutch oil change, the service advisor at the time told me it used the same hydraulic fluid and reservoir as the brakes and since I had recently flushed my brakes I didn't need to worry about it! I knew better and told him he was just plain wrong. The master tech came out and confirmed the error. Geez. Incidentally, I found out a couple of months later that that service rep had been replaced (due to a history of things of which this was just one example).
