Help with new Bilstein B16 install - groaning/creaking noise when steering
Help with new Bilstein B16 install - groaning/creaking noise when steering [w/audio]
Just got Bilstein B16 coilovers installed on my 997.2! Slight problem though, whenever I turn the steering wheel at all, either direction, there's a creaking/groaning noise coming from both the front (imagine walking on old squeaky floorboards). We think it's coming from the upper strut mounts.
Any ideas?
Here's what it sounds like [added 1/30/16]. This is how loud the noise is from inside the car with the windows closed!
Here are some photos in case anything looks out of the ordinary.
Any ideas?
Last edited by gasongasoff; 01-30-2016 at 04:28 PM. Reason: added audio/video clip
Is that the stock, upper bearing plate installed between the upper mount and the silver collar from Bilstein?
That or a missing conical washer that slides over the shock piston are probably the two most likely candidates.
Also if the top nut is over torqued it could create the problem.
There should be a plastic encased needle bearing that goes between the top mount and the Bilstein collar at the top. If you only have a rubber gasket then that's a problem. The shock has to rotate when you turn the wheel and a rubber gasket isn't going to do that.
There is a rubber gasket on the rear shocks since the rears don't turn like the fronts, so maybe you're thinking of that.
The washer you show goes on top and bottom of the top mount. The one I'm referring to slides onto the piston before assembly and basically is the resting point for washer you show when everything is tightened down.
As for over torquing the top nut, I think you'd have to use a torque wrench. I think it's only supposed to be about 20-25lbs but can't remember off the top of my head.
See page 17 of the attached.
The conical washer I'm referring to is shown below the lower curved washer in your pictures and rides on the curved part on the piston that you see in the right hand shock body picture.
Having that coil spring bound up all the way with the adjuster.....does not look right at all. Something is wrong there.....The coils are all bunched up and rubbing on each other. Better read the instructions again or call TPC.
There's nothing wrong with that lower spring completely compressed. It's a helper spring with a very low spring rate, and it functions to make sure the main spring doesn't come out of the perch at full droop.
You may be getting a bit of spring bind when turning - is it only pronounced when you turn the wheel a decent amount (eg. parking, but not when regularly driving)? If it's a bit of spring bind you can install Torrington bearings between the spring and the perch to let the spring rotate freely. This was the issue on my wife's car.
If you look at the diagram from the doc I posted on pg 17, from top to bottom: nut, washer, top mount, bearing case, washer, then conical washer.
The conical washer is an OEM part: 996-343-513-00-OEM - SHOCK CONE WASHER
The bearing case is OEM part: 996 343 515 05 deep-groove ball bearing
with housing
You can find these on the Porsche part diagram, pages 77-78
edit to add: on one B16 install, the tech forgot the conical washer and there was a grinding/groaning whenever I turned the wheel. Your coilovers should be quiet.
edit 2: if you decide to get Torrington bearings or thrust sheets, you need ones with 60mm inside diameter. I added a few thrust sheets to my coilovers for extra slidy-ness.
Got them from FRSport.com 1 044101 Swift 044101 Spring Thrust Sheets Kit 60mm
with housing
DC911S might be onto something too. I looked at my old B16s and I have nowhere near that number of threads showing on the front shock. The Bilsteins have a very narrow range for where you can set the ride height and it's not the whole threaded area of the shock body. That allowable range is also on the doc I attached above.
The diagram in the Bilstein manual is a bit confusing. The correct order of parts is as follows (starting from the top):
1. Bilstein nut
2. Bilstein conical washer
3. Upper strut mount
4. Strut bearing
5. Strut mount support ring
6. Spring shim
7. Bilstein conical washer
8. Bilstein shock rod washer
My guess would be that the support ring is missing from your install. It's an easy mistake to make and does not allow the spring top to come in contact with the strut bearing.
1. Bilstein nut
4. Strut bearing
6. Spring shim
idlook2 and motopix, thank you for explaining the Bilstein install diagram. NOW I understand what they were trying to convey with the dotted rectangles. Ridiculously confusing.
Based on what I can see, I can confirm:
1. Bilstein nut - INSTALLED
2. Bilstein conical washer - INSTALLED
3. Upper strut mount - INSTALLED
4. Strut bearing - INSTALLED
5. Strut mount support ring - INSTALLED
6. Spring shim - INSTALLED
7. Bilstein conical washer - ?????
8. Bilstein shock rod washer - ????
So, how do I know if 7 and 8 were installed, and if they were installed correctly?
