Flywheel question
Hi guys,
We're at the track and the aasco flywheel in our 997 cannot be reused. I have access to a brand new Sachs clutch however no flywheel.
I can get my hands on a 996 flywheel part #996.114.012.03 where the 997 OEM number is 997.113.012.01
Will the 996 flywheel work?
Thanks in advance.
Thanks in advance.
Hi Aussie Jase
if you have the base Carrera with M96.05 3.6L engine, I believe you can use the 996 flywheel. The E 997 parts catalog I have (dated 2010) identifies this as either 996 114 012 03 or 996 114 012 04.
However, if you have the M97.01 engine, I think you will need flywheel part # 997 114 012 00 or 997 114 012 01.
Hope this helps.
Hope this helps.
