PASM wire routing
I am in the process of installing B16 damptronic coilovers and the PASM wire exits from the bottom of the front strut similar to the OEM gt3 coilovers. Does anyone have pictures of how they have routed the wire from the bottom of the strut up to the main harness connection at the top of the strut?
Thanks!
Thanks!
Just checking back in to post how I routed the wire in case anyone else is looking for information in the future. There are several holes (~1" in diameter) located on the inner fender well that lead into the battery compartment. I bought a couple of large grommets to install in these holes and ran the PASM wire through this grommet. I also ran the wire through an empty bracket beneath the hole on the fender well and attached it with a zip tie. Everything appears to clear and plenty of slack for suspension movement as well!
