Keeping the tailpipe clean
Old Jan 11, 2016 | 03:56 PM
ric-ko's Avatar
ric-ko
Default Keeping the tailpipe clean
Hey all-- This may be a stupid post, but I am shocked by how quickly my (non-chrome) tailpipes dirty up. If I clean the car and scrub those pipes, I will find that a short drive turns them back to black.
Do others see this? Tricks to keeping them a tad cleaner? Do chrome exhaust tips wear better than the steel ones?
BTW-- i love our cars.
Old Jan 11, 2016 | 04:05 PM
Racetwin2's Avatar
Racetwin2
What material is it if it's not chrome? I thought all OEM:s were chromed.
I read about several people here who anodise them or powder coat them. Mostly black from what I have read.
Edit: i have chrome and are perfect. Just put on some wheel cleaner when I wash the car, rinse off and they are good to go.
Old Jan 11, 2016 | 04:10 PM
OKB's Avatar
OKB
either chrome or S/S just polish them with light rubbing compound and after that you can wipe them with any cleaner or car wash when ever you wash the car
Old Jan 11, 2016 | 04:31 PM
ric-ko's Avatar
ric-ko
I know how to clean them-- mine just get super dirty quickly. Anybody else see that?
ric-ko's Avatar
ric-ko
Oh-- and whether someing can be done (rejex?) to help keep them clean.
Old Jan 11, 2016 | 04:35 PM
MaddMike's Avatar
MaddMike
Mine are brushed
I have not noticed that they get dirty at a faster rate than any other tail pipes. Does your car have cats?
Old Jan 11, 2016 | 04:54 PM
ric-ko's Avatar
ric-ko
I don't think it has cats. Although it growls periodically.
Old Jan 11, 2016 | 05:11 PM
extanker's Avatar
extanker
exactly what part of the tail pipes are we talking here ? inside or outside ?
Old Jan 11, 2016 | 06:35 PM
Rikky001's Avatar
Rikky001
Maybe get your car checked as the tailpipes should not sooth up. Most probably it is the left (driver) side which is more dirty? Get you engine checked for bore scoring... My internal pipes stay clean but use this polishing ball to keep them clean.
I took my tailpipes of in the weekend for cleaning as they were dirty. Just a 13mm nut hold them in place. Once they are of it is so easy to clean and polish them. Once polished you should be able to keep them clean with a regular wash.
Old Jan 11, 2016 | 07:49 PM
ADias's Avatar
ADias
Stock tail tips are stainless steel. Very easy to clean: any metal polish will do, or soap and water followed by brushing with
3M Scotch Brite 7447 3M Scotch Brite 7447
(red burgundy color) pad.
I see videos of people cleaning the pipes interior forcing water jets inside the exhaust pipes. I think that's silly and asking for trouble.
Old Jan 11, 2016 | 11:00 PM
Philster's Avatar
Philster
Sooty tail pipes can be a sign of a serious engine problem called bore scoring, or Air-Oil Separator issues which should be looked into, particularly if it happens quickly.
Old Jan 11, 2016 | 11:24 PM
ADias's Avatar
ADias
Originally Posted by Philster
Sooty tail pipes can be a sign of a serious engine problem call bore scoring, or Air-Oil Separator issues which should be looked into, particularly if it happens quickly.
Sure if major, but even a perfectly normally running modern engine produces some soot, especially DFIs. Normal.
Old Jan 11, 2016 | 11:50 PM
Rikky001's Avatar
Rikky001
If it is a 997.1 with sooth I would start to get worried as that is not normal. DFI seems to be typical but these engines do not suffer that much - but that is a different topic sufficiently documented.
Old Jan 12, 2016 | 07:18 AM
Philster's Avatar
Philster
They get "super dirty quickly..."
I'd be remiss if I didn't point out bore scoring and AOS issues as possibilities. And my last advice to the last two sooty tailpipe posters worked itself out to one bore scoring and one AOS issue.
Old Jan 12, 2016 | 09:22 AM
wc11's Avatar
wc11
Brushed stainless steel just loves to hold the everyday soot.
I used to spend as much time cleaning the tips with various products I might ad as I did the whole car.
So I replaced them with Fabspeed polished stainless steel tips.
Now it's just paper towel, Windex and 30 seconds.
File Type: jpg
