997 brake upgrade are on Sale!!!
Former Vendor
Whether you are just looking just to replace OE rotors, or upgrade to 380/380mm BBK by reusing OE calipers, or even upgrade to carbon ceramic brakes, RB has a right choice for you.
http://www.racingbrake.com/category-s/7231.htm
The variety of choice is wide but we make the selection simple. All the over-sized brake kits fitment are duly tested and verified per claimed under description.
Everything on the matrix is subject to a 20% discount on both iron and Carbon Ceramic brakes*.
The carbon ceramic brake kits are built with ZR1 discs (394x36 front, 380x34mm rear) and packaged with RB 6pot/4pot track duty calipers. This is the best priced CCM package you can ever find.
CCM discs are the latest version of CCB as equipped on Corvette ZR1 and Camaro Z28, the rotor are designed and built by Racingbrake with rotor hat made from heat treated aluminum alloy, the hardware are made to 10.9 grade. Rotors are fully assembled for bolt on installation.
* First 3 CCM brake kit orders only, after that discount will become 15%.
Discount coupon code will be 997-20. Order is on first come first serve basis, This special holiday sales ends 12/31/15.
