Time to charge battery
I had a dead battery and jumped the car successfully. I ran a test on the battery and it was completely dead. The battery is less than a year old.
How long do you think this should take to charge? I want to take the car out again, but I want to make sure that the battery doesn't go flat again while I'm out.
I connected a 30A charger to it.
Was the car not driven for weeks ?
Seems you have the right kind of charger for a completely flat battery.
Check that the battery voltage is around 12.5 Volts after about an hour off charge and when the engine is running it is above 13.5 Volts.
Use a battery maintainer if not using car for more than a week, standard lead acid batteries don't like deep discharge unless they are designed for that purpose.
A month tops is about as long as I dare leave the car without having it plugged into a trickle charger.
New or not, your battery life has probably been compromised now with the complete discharge.
You are correct I went to my garage after having it charge for like 5-6 hours and it still wasn't enough. Rather than risk it I just put a new battery in. Buying a tender today. Thanks guys.
A completely discharged lead cell battery is toast. I have learned that several times in my own life. I use a tender if my car is not going to be driven for a week.
just happens,
all the best.....
just happens,
all the best.....
Former Vendor
I believe the Porsche chargers are just re-labeled CTEK's, I'm a CTEK dealer if anybody is interested in buying one.
I don't have them on the website so just contact me.
-Jason
-Jason
First, let me say I agree. But....you can attempt a recharge by placing another good battery in parallel with the dead one to get it to start taking a charge. Sometimes this will bring back a totally dead battery because the charger won't see a load in the dead battery by itself and won't charge it.
30A? That is a heavy charge. Great for getting the battery charged up quickly, but it is tough on it. The slower the charge the better. As I understand. If you have the option on your charger, dial it back to 2 or 5 amps. If it is a Carquest battery? take it back and get the to test it on their big expensive tester. It maybe toast. With your bill of sale, they just may replace it. I would try and not mention that your car was not driven for a period of time.
X2 on the battery tender, ie. CTEC or Porsche tender. Something, if your not excising your steed.
Funny. I just replaced my wife's battery on Saturday on her X5. With the aid of the 12 year old, 19 minute job. From tool selection, to tool put away. Dealer wanted $472? Walmart $139. non Black Forest design.
