PPI Results on eBay Car - Buy, Walk, or Run?
I'd recently placed a hold on this car: CLICK ME!
The car looked like a decent deal and the owner agreed to let me complete the PPI before committing to a final purchase. Well, the PPI is back and this is seeming like less of a bargain. But, before I write off the car, I was curious to know everyone's thoughts. The PPI revealed, including repair costs:
The PPI was done at Intersport which I've heard has a bit of a reputation for unnecessary work, but I gave them no indication that the work would be completed by them, so in my mind they aren't incentivized to run up this report for their gain. Regardless, I'm open to everyone's thoughts before I reply back to the owner.
I've never owned a Porsche before and I'm excited at the prospect, but want to make sure I'm in the right car. Apart from what's listed, which feels mostly like deferred maintenance on a car that doesn't get driven a lot, the car seems great...but I have no basis for comparison.
- Water pump pulley wobble and possible expansion tank leak - $2961 for new water pump, thermostat, pulleys, and expansion tank + $365 for coolant flush.
- Misfires on 1, 2, 3, and 6 with cracked/old coils - $2176 for major service and new coils.
- 4/32 and 3/32 wear on old tires (I knew about this one) - ~$1200 for tires + $375 for alignment.
- $165 for brake fluid flush.
- $134 for cowl cleaning.
- And the biggie...uncertain oil leak, could be RMS, could be IMS. Recommended a new clutch as well, but owner states this was done "recently"; this can be verified. Figure a max of $3,800 depending on what's needed.
I'd pass unless there's something really compelling about this car.
Assuming the first two are correct, you want to get them done before driving the car home (you mentioned fly/drive in previous thread I think).
The leak might be something that can be put off can it can develop anytime so recent service does not preculde it. To clarify, it means IMS seal, not the bearing itself.
If you decide to move forward, I'd probably get a 2nd PPI with ASG and plan to leave it there to get the work done.
edit: and I don't recall you mentioning the IMS bearing itself so that's something to plan for since it's a 2005, when the tranny is dropped to fix whichever seal is leaking.
Sounds like he didn't maintain the car.
Are you willing to do the work to get it up to par? You'd have to do most of it before you could drive it.
It's one of those, maybe depending on how you can turn a wrench?
Also, do you have any maintenance records of the oil changes?
If they have been few and far between with those issues, I'd almost be willing to RUN away from it.
Mike
Mike
Let me help you
Let me help you.... combine this PPI with being a none local car etc and the flight costs to get it etc... PASS without one ounce of hesitation. No walk nor run needed, juts a casual stroll...
Keep looking....
Keep looking....
Item #6 alone would make me run away. Uncertain oil leak on a 2005 would not allow me to sleep properly.
Other items seem that it wasn't maintained as it should have.
There a lot of very good 911's out there if you have patience. This one doesn't seem to be one of those.
Those repair costs seem awfully high. Don't let the repair quotes alone scare you away just yet.
I had a new water pump, thermostat and expansion tank installed for about $1600 total at an indy.
Not sure if the full major service is necessary. Plugs and coils if you DIY is about $400 in parts and a couple of hours of your time. Oil change is maybe $60 for DIY. Brake flush is cheap, $20 is fluid and your time. I'd do air filter too. So maybe $500 total if you DIY.
Yup, tires are about $1200. Alignment not always necessary.
Again, fluid is cheap at $20 and should be part of the major service. I'd DIY this one.
I'd go with a detailing product like Back-to-Black or the like first. $10 total. If it's really bad then replace the entire cowl for a new one at about that $134 price.
Likely RMS as it's a common leaking point. Surprised it wasn't repaired/replaced when the "recent" clutch was done. It's a 2005 so the IMS could be "easily" replaced too, depending upon engine serial number. Just guessing here but maybe another $1500?
So what to do? You have upwards of $5K in repairs depending upon some unknowns with the oil leak and if you will go with an indy or DIY. I'd want full docs on the clutch repair and question the seller about the oil leak some more. Then I'd ask for the repair costs minus the cost of the tires off the asking price, or roughly $30K to close the deal. Otherwise move on.
At $30K it would be a great deal, even with the repairs, but there are a lot of 997s out there...
Understood. It sounds like you already know the answer and want someone to change your mind then. Dissappointing to get less than stellar PPI results. But that's exactly why you do a PPI. It's time to move on.
Keep in mind a clean PPI doesn't prevent these things from coming up in a few thousand miles either. In some sense it's better that it happens now so you can negotiate the price vs. being stuck with the bill later.
The fact that the paint came back at uniform depth, it has all the options I'm really looking for, and nothing worrying in the overrev, makes me a little tempted--though cautious--if the price is right.
