Computer resets, PSM Failure, window stays down
My 2008 997 is acting very strangely. The best way to describe it is that it feels like you are disconnecting the battery for a second.
This is what happens:
- I turn off the car after driving it
- the window that slightly lowers to open the door stays down
- I need to then turn the car back on (don't push the plug, just turn on electrical) in order to raise the window
- It will show psm light
This doesn't always happen but does about half the time that I turn the car off. It seems to be more likely to happen if I turn off the ignition but leave the key in the ignition for a little longer than normal.
Any ideas what this can be?
