What Causes Sharkwerks Bypass Vibration?
Old 10-28-2015, 12:55 PM
Crester
Crester's Avatar
Default What Causes Sharkwerks Bypass Vibration?
I'm considering getting the Sharkwerks bypass pipe for my 997.2 C4S because I just want a "bit more" sound. I'm seeing some people complain about vibrations especially while idling. Even Sharkwerks acknowledges that a "small percentage" of clients have this vibration problem. What is causing this vibration and how common is it?
Edit: It's not just Sharkwerks... all of the bypass pipes made cause vibration.
Old 10-28-2015, 01:07 PM
GT2RSobsessed
GT2RSobsessed's Avatar
I just got the sharkwerks bypass + fister exhaust installed on my 997.2 C2S and I don't have any vibration. 6 speed manual. So +1 for it not occuring. Also I experienced Sharkwerks great customer service, so if there is any problem I'm sure they could help you resolve the problem or give you a refund.
Old 10-28-2015, 01:08 PM
jcsomerv
jcsomerv's Avatar
Vibration happens with PDK only (says that on their site). Don't know what causes. I have MT and SharkWerks with no issues.
Old 10-28-2015, 01:53 PM
ltcjmramos
ltcjmramos's Avatar
Got the vibration (PDK), and, frankly, as I've said on other threads on this, I like it. Reminds me of my ex-6GT3, a real sports car feel.
Old 10-28-2015, 03:00 PM
Astur
Astur's Avatar
Wow! The Sharkworks pipes is/was going to be my next modification but since my 992.2 C2 has PDK, I think that I'll hold off until I get more feedback from users who have theirs installed.
Anyone have the BB (Billy Boat) version installed and also have the vibration issue with their equipped PDK cars?
Old 10-28-2015, 03:05 PM
ltcjmramos
ltcjmramos's Avatar
It occurs to me that most folks talk about a vibration, which I would characterize as a constant buzz feel. Mine is more like a rough idle, jiggles my butt a bit. As I said, I have no issue with it.
Old 10-28-2015, 03:13 PM
Yet anothercrisis
Yet anothercrisis's Avatar
I have PDK and Sharkwerks. The vibration is there, but it is very minor. I truly didn't notice it until I read the entire Sharkwerks website a month or so after I installed the bypass. Once I read and then recognized it, the vibration was noticeable. But just that, noticeable. And only within 50 RPMs of the idle RPM set. Sharkwerks can adjust it out, but you have to send them the control module. I didn't bother.
Old 10-28-2015, 03:34 PM
nwGTS
nwGTS's Avatar
90% of the vibration issues can be attributed to incorrect torquing of the bolts to the cats and inboard brace. Though I have a 6MT, I had issues on installation, retorqued the bolts and have had zero issues since (Apr 15).
Old 10-28-2015, 03:39 PM
Fred R. C4S
Fred R. C4S's Avatar
Over 15,000 miles with Sharkworks bypass on my PDK GTS and no vibration to report.
Sooner
Sooner's Avatar
I have the Sharkwerks bypass on my '09 C4S PDK with stock side mufflers. No vibration that I am aware of.
Old 10-28-2015, 03:41 PM
SpeedyD
SpeedyD's Avatar
Just for another data point, I have SW w/Fisters on .2 C4S (6MT) and all good!
Old 10-28-2015, 04:17 PM
Chrisjd
Chrisjd's Avatar
I have the Sharkwerks bypass with PDK. A little vibration at idle but nothing I would categorize as annoying. Had some difficulties when I added an EVOMS tune and an IPD Plenum. The car would throw a CEL. The code was for a MAF sensor. Changed it out and still had had the CEL. After close to 2 weeks in and out of the dealership they finally contacted EVOMS and was told with the mods I have on the car and because it is a PDK the idle needs to be raised. Once they raised it, No CEL, no vibration. From what I was told It seems the CEL would was triggered as the PDK shifted into first gear, the car would lurch and the idle would drop and the MAF would see too much air for that specific rpm at idle.
upier
upier's Avatar
I have the Sharkwerks bypass with a PDK. I had the vibration but fixed it by retorquing bolts to proper setting. They were too tight originally.
Old 10-28-2015, 05:40 PM
OKB
OKB's Avatar
you are cutting out the center muffler with a bypass pipe, thats what it is for. it reduces alittle of the center mufflers restriction to air flow, thats what its for.
So you are changing the air flow of the engine and in the 3.8 that is causing a little vibration.
The 997.2 PDK all have a little shutter/vibrations at idle and on take off. Its tolerated and explained away by porsche as a characteristic of the car. They also set their idle rpm to accommodate many perimeters , average driver comfort, general driveability, gas mileage, epa emissions, many reasons.
If you increase idle rpm a little, it smooths out alot of those shutters and vibrations.
Like above, I had a crossover exhaust and added a EVOMS ECU and we increased the idle untill it smoothed most of it out.
If you are not adjusting your idle i doubt if theres much remedy , its a characteristic of the 3.8 PDK when you put on a bypass
Old 10-28-2015, 06:47 PM
Astur
Astur's Avatar
OK... Some of the latest posts mention vibration on their 3.8L engines. So does that mean that those of us who have a 997.2 with the 3.6L engine with PDK will NOT have this "Vibration"?
Also and within this topic, I asked if this problem also manifests itself on 997.2 cars with the BB (Billy Boat) cross pipes and PDK's. Anyone have any comment or cares to share experiences?
Quick Reply: What Causes Sharkwerks Bypass Vibration?
