Steering Wheel Locked - No Start
Old Sep 21, 2015 | 11:01 AM
beden1's Avatar
beden1
Default Steering Wheel Locked - No Start
I parked my 2012 911 GTS yesterday with the front wheels turned to the left on a flat surface. When I tried to start the car, there was nothing when turning the key. I saw a message stating that my steering wheel was locked. I tried moving the SW while turning the key and still nothing, and even tried locking and unlocking the door with the key fob to see if it would free up the steering wheel. After 10 minutes, I played with the SW again and the car finally started.
Is this just a fluke where I stopped the car with the steering wheel too hard over to the left, and placing too much pressure on the ignition, or is this a problem for the service department to figure out?
Old Sep 21, 2015 | 11:17 AM
nwGTS's Avatar
nwGTS
If it happens again check with your dealer. Otherwise, it's probably just binding pressure on the clockspring SW lock.
Old Sep 21, 2015 | 12:48 PM
Iceter's Avatar
Iceter
+1. This happens in a lot of cars and it has been my experience that people are hesitant to pull on the wheel with the force necessary--they're afraid they're going to break something.
Sometimes, you have to yank the ever living $hit out of the wheel in both directions to get it to free itself.
Old Sep 21, 2015 | 01:02 PM
BIG smoke's Avatar
BIG smoke
Wiggle wheel, while turning key.
Sorry? Does the key turn?
Old Sep 21, 2015 | 02:24 PM
jhbrennan's Avatar
jhbrennan
IIRC when I insert my key I hear a loud "clunk" indicating that the steering wheel is unlocked. Are you getting that sound?
Old Sep 21, 2015 | 03:32 PM
beden1's Avatar
beden1
Maybe I'm doing something wrong by manually locking the steering wheel before removing the ignition key? For example, I pull into the garage, put the car in neutral and take my foot off the clutch pedal (manual transmission), turn the key off and then turn the steering wheel to the left, and then pull the key out, let go of the steering wheel and it's locked. I then pull up on the parking brake and shift into 3rd gear.
When I had the problem this weekend, I had pulled into a parking spot and stopped with the front wheels hard left, and then manually locked the steering wheel as I normally would.
The Porsche ignition and steering lock mechanism seems to operate more electronically than mechanically. I think, the Porsche steering wheel lock also operates on and off when you lock and unlock the car, and without having to manually lock the steering wheel (I know it unlocks the steering wheel when you unlock the car)? When I had the problem, the steering wheel probably had too much pressure on it and was not able to unlock itself.
Should I not manually lock the wheel when stopping the car and let it lock itself, or?
Old Sep 21, 2015 | 04:29 PM
BIG smoke's Avatar
BIG smoke
You are the first I have heard of, manually locking a wheel.
I believe there is one position that it locks. And that is the way with most cars.
I never intentionally lock it. Sometimes I push my car in the garage, the steering often clicks lock when I get to that point in the wheel rotation?
Don't know why you would manually lock the steering every time?
Old Sep 21, 2015 | 06:08 PM
beden1's Avatar
beden1
Old habit I guess, as that's what you needed to do to lock the steering wheel on most cars.
Old Sep 21, 2015 | 06:09 PM
beden1's Avatar
beden1
The key turned fine. Nothing happened when the key did turn. I kept jiggling the steering wheel and locking and unlocking the car with the key fob. After about 10 minutes, the car started.
Old Sep 22, 2015 | 05:25 PM
Minok's Avatar
Minok
This happens when the steering wheel is just aligned with one of the locking positions and there is some pressure on the wheel against the lock. The insertion of the key doesn't unlock the wheel because of the pressure of the steering wheel against the lock. You just need to slightly turn the wheel away from the lock (there is a warning message on the OBC display about the steering lock when this happens) - gently wiggling. The relieved pressure has always resulted in my wheel lock then disengaging. Clunk. I can then turn the wheel and more importantly, start the car.
Old Aug 26, 2018 | 07:40 PM
tomc_mets's Avatar
tomc_mets
Sir Thomas Lord of All Mets Fans
Thank goodness for RL. Just went to move the 997, and the above message pooped up. 3 secs of freaking out. 5 seconds of Googling RL, brought up this thread. Voila! Crazy technology!
T
Old Aug 4, 2021 | 09:12 AM
SoundQ's Avatar
SoundQ
I have a 2017 991.2 and it does the same thing ocassionally (Steering Wheel Lock Fault). BUT it's only done it WHILE driving! The rear wing raises and gets stuck, the top wont go up or down and same with the wind deflector. If I turn the car off it wont start. But wait 5 minutes and it will but then will display an "Engine Fault" and says "driving permitted" but want's me to take it to the dealer. It will be fine, no other faults displayed and eventually, about 3-4 start/stop cycles the lights go away.
I don't know what it is but will have to go to the dealer eventually but was wondering if ANYONE has a clue to what it is or experienced anything like it?
