Keyed Electric in engine compartment?
I am thinking of installing a WI FI backup/rear view camera on my 997 Cab. I would like to find a keyed source in the engine compartment that way I could use the cam as backup cam or rear view (esp in a Cab). If I have to run into the passenger compartment to get power I will just go ahead and use a hard wired system. If this has been covered please send me to it, I have use every combination I could think of in search.
Rick
Rick
Why would you need a back up camera? When I get into my car I walk around it so I know if something is behind me that I can't see from inside the car. Then I look over my shoulder as I back up. It has worked for over a century of automotive engineering.
John ... as you get older your body gets stiffer. It becomes harder to turn your head, even to check the mirrors. You see this reality every day in normal driving by simply observing others!
The camera should stay on, 24-7. No need for a switched supply.
