Upshift
Upshift
For those of you with manuals, where (rpms) is your typical upshift? Is there a factory recommended rpm upshift? I'm curious because I find that shifting is much smoother in these cars if you hold until about 5000-5500 rpms, but that seems high for everyday driving. Of course, it's much more fun to drive that way! (albeit a gas guzzler). Perhaps the smoother shift at higher rpms phenomenon is just demonstrative evidence that these engines' blood line is from the track? Whatever the reason, I just go with it and shift at 5000 for a smooth transition.
I believe that there is an icon on the LED display (a small triangular arrow) that lights up when the ECU coded/factory suggested up-shift should take place. It is pathetically low on the RPM scale (like 2,200 RPMs). Personally, in everyday driving I shift at about 4K RPMs but this depends on the traffic and speed it is moving at - at 40 mph in the city I tend to just shift into 3rd because it is just easier. When the roads are open I tend to shift closer to 5K RPMs (trying to keep in mind that we have high-revving engines that don't have to be nursed by sifting at 2,500 RPMs.
OP, Yes, my car likes shifting under heavy load above 5k. Not always doable but I try and take it up above 6k when I can.
Normal driving I usually shift between 3,600 to 4,200 RPMs. Spirited driving usually 4,500+ if road conditions and traffic allows. The problem when driving on public roads, is the faster you go, the faster you run out of open road.
When driving however, I shift according to my ear as opposed to looking at the tachometer.
Agreed..... I actually play with this every once in a while try the car's advice and can't imagine ever really driving that way. I guess you would use it if you were on perfectly flat roads (or going downhill) and enjoyed very slow acceleration. It really is stupid and frankly, I can't imagine anyone actually using it as a shift guide.
I wonder if it is there to prevent some regulatory body from challenging Porsche's MPG claims.
Peace
Bruce in Philly
The consumption-orientated gear shift indicator A
on the display panel of the on-board computer
assists a fuel-saving driving style. The gear shift
indicator lights up as a recommendation to shift
up to the next-higher gear depending on the
selected gear, engine rpm and accelerator pedal
position.
f When the gear shift indicator A lights up,
change to the next higher gear to decrease
fuel consumption.
Anyone know how to shut the indicator off?
To reduce cylinder bore wear Excellence mag's tech writers suggest keeping rpm 3K and up so I up shift at an rpm that will not drop the revs below 3K. Did in our prior 997s and now in our '07 GT3. If I am going to put any load on the motor I will drop down another gear. Reading an English Porsche mag they discuss bore scuffing on the 997's which is worse on the Tip cars which tend to up shift at lower rpm. Some of their used dealers will not resell 997 Tip cars or 3.8 S cars. Me, I keep the rpm up.
All the best......
All the best......
The arrow exists on the 997.2 - it's there for economy not performance. Here's what the manual says:
position.
fuel consumption.
position.
fuel consumption.
All the best......
All the best......
