Water Pump - Interesting Info
Here is the reasoning as I've gathered from prior forum posts: Occasionally the failure of our water pumps is not a typical bearing, seal, or shaft failure with the resulting noise and/or leaks. The bigger problem occurs when the non-metal impeller blades disintegrate and chunks of the blades get caught in the engine's coolant channels and restrict coolant flow along some of these channels. That is typically why people here consider a proactive change.
Okay, I just noticed the other water pump thread going on in parallel and have to say that Ericson38 describes this much better than me. See his post at https://rennlist.com/forums/997-foru...uestion.html#8
Since I am considering a higher mileage (58301) 07 C4 Targa I have started lurking on this board. The threads are interesting, but if I was to make a slightly uninformed comment about the failures being talked about can changing the water pump as preventive maintenance I would ask if the failure is just part of mechanical wear and who is to say the replacement would fail after installation from just bad luck on my part?
Last week my 2005 997 carrera water pump start leaking, at 97k it seems this is not unusual. I collected the car yesterday after they replaced the pump. My problem is I can see from the part number they have gone an fitted a 996 mk2 water pump, part no 99610601157.
Car now drives fine, water temp and oil temp sitting in the same place it used to, no leaking.
I've read the impeller size was changed by 2mm, and even the material may have been changed from plastic / metal / ceramic.....do I need to go back to the garage and insist they change it or do you think I'm ok and leave it as is. It seems the 996 mk2 is interchangeable with the 997 mk1 WP....but have I just downgraded and if so does it actually matter? Car is used daily for road work only. Thanks!
AFAIK, stock Audi pumps are like Porsche, composite. If yours was metal, could it be that someone replaced it? Those composite pumps are a weak spot on the Audi too. Everyone changes them to metal and replaces them on every belt service (I do too).
The water pump was the original and the replacement is an OEM part from Porsche....
Again, maybe its the Engineer in me, but the interesting part is how good it looked in comparison to those with much less miles (half) and half as old. As the original owner, I've kept to the book recommendations on maintenance and have done nothing special as far as I can tell.
My interesting is not your level of interesting....sure the response would have been different if the thread title was "my water pump ate itself and now my engine is kaput".
Sorry, just trying to add some information to the forum as every bit helps.
With your context in mind and in the pursuit of insight for others, how long have you owned the car and what, if any, has your approach been to lengthen the life of that system - have you changed out the coolant regularly, do you have a third radiator, are you a track junkie, etc??
Light tracking, no 3rd radiator as I never have seen the oil temp over 230F at the track with 95F ambient, but coolant was has been changed 3 times, the last time being with the water pump. At 60k I'll do another major (I do every 20k), and this time the coil packs will be changed as well and maybe the AOS. Still running the original clutch and RMS as well.
Does this help extend the life? Perhaps, but I have never had a CEL and the car always gets me home....waste of money, could be, but the next owner will benefit as it will most likely be my son.
I don't think it was necessary to just go out and replace a perfectly good water pump. You could have removed the serpentine belt and rotated the pulley to get a feel for it. Wiggled it a bit and visually check for leaks or signs of leaks. Water pumps typically give you visual or audible indications before they go out. I understand your concerns and maybe you had good personal reasons for doing this but for the most part, this was pretty foolish.
I'm in agreement with this for water pumps. I pull the airbox and serp. belt to check all the pulley bearings. If something spins quickly by hand or sounds dry it get's replaced. Means the original bearing grease is gone and the bearing will begin to wear much faster. Also check for torsional and lateral runout. Any play and I replace.
