997.2 suspension changes?
hey guys,
Looking to upgrade from my 2006 CS to a 2010-11 turbo 997.2. Have there been any changes to the suspension/ride quality between these models? I'm aware of the engine/tranny, infotainment, etc, changes but not sure on the suspension.
Any help or links would be great!
Thank you,
Brandon
Thank you,
Brandon
Yes. The PASM system was refined and I've been told is much better. Smoother and quicker reactions and more adaptive to road conditions. This is just based off of discussions with friends.
Thanks for the reply.
Don't spend money needlessly: you'll never achieve the cushy ride of a sedan. This is a sport car and the ride is consistent with the handling. The 991 is smoother and a lot of RL'ers prefer the 997 because of that.
I am aware it wont ride like a sedan Just want it to ride a bit better than my current car. I have driven/rode in several 991's and they are a drastic improvement over my 2006. Im hoping the 997.2 will be somewhere in between!
Keep in mind that a lot of other factors can make or break your ride quality, like.....the age of the tires, how old are your shock absorbers, also mounts pretty much anything that is still in the car since it left the factory it is a 9 year old car. Please don't take it personally but at the end of the day this is a sports car with comfort being maybe a second thought to performance.
The following images show excerpts from a book I have on the 997.2 changes. You can see that there were some made for comfort.
Thanks for the great info folks! Rest assure, the turbo upgrade is not about the ride quality, that's just an added bonus
However you look at it, the 997.2 has many significant changes, most for the better.
Can someone show me the hydraulic bearing on the front control arm? ive never seen that and dont remember seeing when working on my suspension.
Good question... I was curious about that too. It seems it may have been on models starting in 2006 if this article is correct.
http://www.gospecracing.com/forums/showthread.php?p=233
Edit: I hope this doesn't seem like I'm stealing the OPs thread. Just want to know the different in CA 'puck' b/w 997.1 and 997.2.
After a bit more Googling around... here's my summary of the mostly scientific writings I see on the subject:
Hydraulic bushings contain fluid in channels and chambers within the bushing itself. Its not clear to me what this fluid is but I assume it is reasonably viscous like oil. The configurations and lengths of these channels and chambers can be tuned to dampen out certain frequencies that are deemed undesirable from a comfort/sound point-of-view, but at the same time can act fairly rigidly when exposed to other forces and pressures that could affect handling.
Here is a couple of sample sources of this info:
http://www.contitech.de/pages/produk...uchsen_en.html
https://www.deepdyve.com/lp/elsevier...ges-rXoeboMEdK
Yup, fluid filled. Mine leaked a little over time, another wear item I supposed (2006 C2S). I used it as an excuse to upgrade to GT3 two-piece LCA's to get more negative camber up front. They also have a rubber puck instead of the hydraulic one.
