Oil Change
Old Jun 15, 2015 | 11:35 PM
Dr.J's Avatar
Dr.J
Default Oil Change
Hi, I'm about the change the oil in my 06 C2s for the first time (the car is new to me) and was told I should let the oil drain for a prolonged period of time, by one friend, overnight. So, my questions: is this true and if so, is there any danger of the pump losing its prime (assume not if it's a dry sump, but thought I'd better ask to be sure)?
thanks
John
Old Jun 15, 2015 | 11:42 PM
SteveFromMN's Avatar
SteveFromMN
Originally Posted by Dr.J
Hi, I'm about the change the oil in my 06 C2s for the first time (the car is new to me) and was told I should let the oil drain for a prolonged period of time, by one friend, overnight. So, my questions: is this true and if so, is there any danger of the pump losing its prime (assume not if it's a dry sump, but thought I'd better ask to be sure)? thanks John
Just drain it. You don't have to get the last drop out. The oil that is left is not poison. The oil pumps do not need priming. I have been changing oil for over 50 years.
For the last 15 Porsche's. Before that Corvettes.
Old Jun 16, 2015 | 12:18 AM
gvcap10's Avatar
gvcap10
+1, everyone goes overboard with oil changes, etc. Grab a wrench and get after it.
Old Jun 16, 2015 | 12:54 AM
CosmosC4S's Avatar
CosmosC4S
Let it drain for 20-30 mins is good enough, if the oil is warm. If you have time or things to do, then let it sit longer.
Go grab a beer, finish it, come back to change your oil filter, look around and clean the engine bay, check the air filters, etc....and it'll be about time to put in the fresh oil.
Old Jun 16, 2015 | 10:54 AM
Quadcammer's Avatar
Quadcammer
+1 to the above.
Its also not a dry sump.
Old Jun 16, 2015 | 11:11 AM
Dr.J's Avatar
Dr.J
Alright, thank you!
Old Jun 16, 2015 | 01:24 PM
Ericson38's Avatar
Ericson38
Let the engine cool off so that the drain plug comes out easily. Hot cases and drain plug will result in higher break away torque being required.
Old Jun 16, 2015 | 11:31 PM
Dr.J's Avatar
Dr.J
OK, thanks!
Old Jun 17, 2015 | 09:44 AM
Mumbles's Avatar
Mumbles
I let my hot oil drain for a few hours. It drips out for ages.
Old Jun 17, 2015 | 10:10 AM
wc11's Avatar
wc11
Well considering a dealer oil change is typically an hour, I doubt you need much more time than that.
I wait about 20 minutes myself with a warm engine.
Besides, I'm changing every 5000 km
