Flat Tire
Footwell outlet is accessories only protected by a 7.5 amp fuse. Wiring gauge is generally matched to fuse size and I would not recommend putting a larger fuse in. The cigarette lighter needs more power, should have larger gauge wiring, and a 15 amp fuse. This is where I would plug the compressor in.
Right...but don't think it's an option. Owner's manual specifically says use cigarette lighter. If you review posts about this issue for the last 7 years you'll see many instances of blown fuses when socket other than cigarette lighter socket was used. Hope there are no more flats in your future.
And may we all stay away from the shoulder/debris and be flat free!
