Camshaft Position Sensor DIY?
Hey RL'ers,
Had a CEL come up the other day. Scanning said it was a P3042 - low limit on camshaft position sensor bank 1. Cleared the code and it eventually came back and then the next day the car stalled and wouldn't re-start with the same code. '05 Carrera S btw, but the p/n for S vs. non-S is the same.
I ended up getting a sensor and from what I understand, bank 1 is drivers side. Looking at the parts diagram/manual, it seems to be on the end of the end in the engine bay, on the drivers side just in front of the engine mount (underneath the coolant tank hose).
Is there any trick to replacing it? Just the one bolt or do I have do something extreme like dropping the engine?
Thanks in advance.
Thanks in advance.
Basic Sponsor
If you head on over to this Tech Article right here and look at figure 5 you should see the sensor you're asking about. Hope this helps.
-Luccia
-Luccia
Your Trusted Source For DIY and Parts
FREE SHIPPING over $99 click here
Porsche Parts | DIY Tech Articles | Facebook | Twitter | Instagram | YouTube | Promos
888.280.7799 | 6am - 5pm PST
Thanks Luccia,
I did see that article. For those of you interested, pn is 997-606-106-03-M14. Same pn for bank 1 and bank 2.
My question is do you need to disconnect anything ie. coolant hoses or even drop the engine to remove it?
Basic Sponsor
Due to the variance between the first gen 996 and second gen 997 I can't accurately answer that. It's honestly been a while since we've seen one with the motor in the car as most of the time the motors are removed. My suggestion would to put the car up and take a look under it.
-Luccia
-Luccia
At this point you should be able to access the camshaft position sensor & plug. If it is too tight of a fit you can drop the engine about 1.5 - 2 inches max for additional room. Just make sure to keep it supported. This is a temporary drop so you can't leave it this way too long. Remove and replace the sensor and put everything back the way you found it (might want to take a picture at the start if you are unsure). Good luck.
I replaced both on mine without dropping the engine. The first camp position sensor is easy to get to (behind the air box). For the second you'll need to remove the passenger rear wheel. You'll be able to see it and may need to use swivel adapters to get to the bolt that holds it in place.
3rd Gear
do you have images or reference of the location of the 2 sensors please? Thank you so much in advance
