Inoperative power driver's seat
Did you look under the seat to see if something got wedged the last time you shifted the seat all the way forward or back. I do that when cleaning the interior and invariably I find stuff from the back seat under the front seat.
Double check fuse.
You can always test the motors with a battery. I doubt all of your motors went bad. I posted the pin out of the connectors once, you can at least test to see if you are getting 12V.
Are both seats having issues or just drivers?
I think my fuse panel is actually mislabeled so you might want to check an extra fuse or two.
Memory or non memory?
