Warming the car up - PSE and Sports+?
In reading the threads here on warming the car up before driving, I noticed a couple of comments about PSE and Sports mode. The posters seemed to suggest that even *after" idling the car for a couple of minutes, neither PSE nor Sports mode should be engaged for some additional period of time.
Rather than re-start a convo on the "correct" way to warm the engine (since it's been debated extensively here) - do people have specific recommendations on when to engage PSE or Sports mode?
I idle the GTS (PDK) on these cold NE mornings for about 90 seconds to get the revs to ~700/800, then drive off. Would somehow engaging PSE or Sports at the same time damage the engine?
Thanks!
Thanks!
Thanks!
Thanks!
As for PSE, I have Fister (PSE always on). I can only hope this does not have implications on the warm up!
I agree on the 90 second rule ... It gives me time for a quick walk around and light check (old habits die hard).
997.2 C4S for the record.
I too allow a minute or so (whatever it takes for the idle to settle) but as soon as I leave my drive, PSE & Sport mode get pressed. I of course do not rev over 3000-3500 until fully warm but the sport mode IMO allows for easier take off from a stop (manual trans).
When in doubt, I'd say just go by the manual, which should be conservative. Manual states to keep RPM below 4200 until engine is warm (~5 minutes). As long as you can resist the urge "push it" in sport mode, my experience is "PDK-auto" will generally not shift past 4200 RPM even in sport mode when driven conservatively.
From 997.2 manual:
f When starting the engine, be ready to drive
immediately.
Drive vehicle at moderate speeds and avoid
engine speeds above 4,200 rpm during the
first 5 minutes.
f Do not let the engine idle to warm up.
From 997.2 manual:
immediately.
first 5 minutes.
Old habits are difficult to change - many folks let the car warm up at idle for a minute or so. I believe owner's manual verbiage has more to do with EPA concerns than anything else.
