Non Bose System Wiring Diagram
Old Mar 4, 2015 | 12:22 PM
shardul's Avatar
shardul
Default Non Bose System Wiring Diagram
I am going to be installing some aftermarket speakers. I have a non bose system. Can someone post speaker wire + and - colors so I dont have to connect a 9v battery to figure out the polarity of the wires to all the speakers in the car.
Thank you
Old Mar 4, 2015 | 12:26 PM
Psymon's Avatar
Psymon
I've thinking about replacing mine too, which speaker do you have in mind? And do you know the size of the speakers required? Thx
Old Mar 4, 2015 | 12:56 PM
shardul's Avatar
shardul
after doing some research and being helped my forums member.
speaker swap only. no amp etc etc
8" Focal IS200 for door woofers and adapter rings from Delrey customs
2 x tweeters are supplied with focal IS200 that can be used to swap the factory ones
4 " Focal 100 CVX for front door mid range speakers
I am going to leave the 4" rear panel speakers as is for now and disconnect center dash speaker
Old Mar 4, 2015 | 01:15 PM
Psymon's Avatar
Psymon
Cool. Thanks. I'll look into these then.
Good luck with this project and look forward to your update!
Old Mar 4, 2015 | 01:24 PM
Blue Chip's Avatar
Blue Chip
Can't wait to hear about it.
Old Apr 3, 2015 | 07:04 PM
vern1's Avatar
vern1
How do you disconnect the center dash speaker?? I can't find any info on this
Old Jul 23, 2015 | 01:31 PM
Psymon's Avatar
Psymon
Hi Shardul,
Have you replaced the speakers already? If so are you have with the result?
I've taken down the door panels to fix the door handles, so I'm go to replace the speakers as well.
Thanks.
