OZ Ultraleggeras
Anyone have the 19" OZ Ultraleggeras on a narrow body Pcar? Perhaps a pic to share? I see a variety of pics from the usual Google search, but there is no detail on offsets from the random Google pics I find. I'm wondering if the offsets suggested by TireRack (55 front, 65 rear) will fit my 997.1 C2S well. I'd like to avoid spacers if I can, so hoping the above offsets will look nice.
They're nice wheels for the $$. Big improvement in offsets for sure. No spacers in this example. 8.5's and 12's. This is on the tail of the dragon. I've since had the wheels powder coated darker gloss grey. Narrow body GT3 offsets will fit just fine. My street (OZ) and track (CCW) wheels are both GT3 fitment
235/35 front, 305/30 rears. No issues whatsoever or mods required, plug and play.
If you set your "car" on Tire Rack as the GT3, and select those Ultraleggeras, they will fit your narrow body car perfectly.
Alternatively you can do the math yourself.
Find out what your stock wheels diameter and offsets are, measure the amount of gap you have from wheel to fender, that's the amount of offset you have to play with (factoring in different widths . . . . )
1010tires offset calculator can help you out with this.
I'm running stock PASM with H&R springs, GT3 adjustable roll bars on Tarret drop links, OEM GT3 lower control arms, and Tarret monoball rear toe links. Alignment is: -2.9 front camber 0 total front toe, -2.1 rear camber .4mm total rear toe in.
